Hi @zhu808.
I managed to solve the Open the door display after searching everything.
I have made a post in another topic that explains the procedure that worked for me.
See bellow
Procedures that were done prior to fixing it:
1. Checked D5 Diode (As i removed Battery holder ) ,was ok.
2. Install NVRam.
3. Checked Voltage from Power Supply -Ok
4. Checked Door Switch -Ok
5. Check 6802 Ic- Ok.
6. Burned in Epprom a leon's Test Chip. Installed in 5C and test in work bench results.
7.Alphanumeric Segment/Sound Control Pia at 8B should had pins 3-17 high & Low in test mode. I found that pin 14-17 were low .
8. Install a new socket and new 6821 PIA.
In General you should have on hand a logic Probe, a Leon Test Chip and a Power supply (From old computer power board )
Check Data east repair procedures that are great tool with step to step guidance.https://pinwiki.com/wiki/index.php?title=Leon_Borre_Data_East_CPU_Board_Repair
I found that Pia's are prone to failure. Check them with logic Probe. A schematic is needed also.
I hope i helped somehow.
