(Topic ID: 223819)
Pharaoh Start Up Issues
By CUJO
1 year ago
  • 17 posts
  • 5 Pinsiders participating
  • Latest reply 1 year ago by CUJO
Williams_Pharaoh Switch Matrix Chart.pdf (PDF preview)
#1 1 year ago
Playing Pharaoh the other night, the ball got stuck in the lower right kick out and wouldn't fire it out on it's own.
I shut the pin off, powered it on and that kickout works now.
I noticed when I start a new game and if I keep adding players till I get 4 players, every time I press START again I get 12,000 points added to the current players score (Player One since I haven't even started the first ball).
Any ideas?
I also took out the balls, lifted the playfield and started a game that way.
I notice that same lower right kickout fires every time I press START with no credits on the game if this clue helps.
#2 1 year ago
Sounds like some kind of switch matrix issue. The start button and lower eject are in the same row. Do any of the other switches in that row cause the eject hole to fire?
When you press start in switch test, what switch numbers register?
#3 1 year ago
Quoted from zacaj:
I'll have to get my manual out to learn how to get in switch test. It's been a long time since I did that.
#4 1 year ago
I also noticed that the other left side kicker that fires the ball to the upper playfield will fire right after the lower right kickout when I press the START button.
#5 1 year ago
So finally getting a chance to revisit this issue.
So the ROW would include the START button (credit button) and the HIDDEN TOMB SHOOTER (see attached PDF)?
I'm going to have to figure out what the HIDDEN TOMB SHOOTER is to test that switch and see if it toggles the others.
#6 1 year ago
It's the switch in front of the kicker under the upper playfield on the left
#7 1 year ago
I'm no System 6 or 7 expert.
But I was able to reset the high score using the coin door buttons! DOH!
Is there a tutorial or video on how to use those buttons to get to switch test mode?
Sorry but all I found on YouTube was an out of focus video with a guy explaining it and all I got was a headache trying to see it.
#8 1 year ago
https://www.ipdb.org/files/1778/Williams_1981_Pharaoh_Instruction_Booklet.pdf
Instructions for getting into test modes.
Consider sending a couple of $ to IPDB. They are an invaluable resource!
#9 1 year ago
Quoted from BobLangelius:
That was a big help. I have the manual for Pharaoh but none of this info was in it.
I will donate some $$$ to IPDB.
#10 1 year ago
Quoted from CUJO:
Were you able to get into switch test? If not I could try to make a video of mine showing it
#11 1 year ago
Quoted from CUJO:
IPDB is the best, I'm on there 3-4 times a week.
If you need Pharaoh photos i have a bunch of PF swap and cabinet photos...
#12 1 year ago
Quoted from zacaj:
Now that the weekend is "starting" and it's raining, I have some time today and tomorrow to try the switch test.
I'd appreciate a video on it. There isn't really one out there I could find (at least that was clear/concise).
THANKS!
CuJo
#13 1 year ago
I had a lot of problems with my game with the upper scoop. Adjusted the switches and it worked great. I would suggest one thing to do with your game. Change the fuse holders underneath the playfield. They are poor in design.
#14 1 year ago
Quoted from CUJO:
CuJo
Are you having problems reading the manual?
Switch tests audits and adjustments on a sys 7 are pretty straightforward. Read the manual and step through it.
When you do it once it will make sense.
Pharaoh BK JL and Solar Fire are all the same so you could search for resources on those too if you can’t figure it out.
#15 1 year ago
Thanks for giving me a little 'push'.
Appears I did not have the complete manual online, just in paper form which I dug out of my bookcase.
So in SWITCH TEST (03), I get stuck switches, in this order on display show up: 21,23,22, all which appear
to be the UPPER CENTER 3-BANK Target(s).
I will visually inspect that now.
Update:
Ok , so all 3 of those targets were in down position.
Reset them all by hand and NO switch errors.
Ran solenoid test (02) and all solenoids fired.
Will put playfield down and see what happens.
#16 1 year ago
Now that you've got those cleared out, try hitting the start button, lower eject, and hidden tomb switches, see if each one only registers the correct switch
#17 1 year ago
Yep...Switch Test works as should ..no open switches.
Lowered playfield. Powered on. No sound..no start..
Make sure two balls in game. There is.
Power on again with both lower balls where they needed to be to start.
VOILA!
No 12,000 point randomness, all good. Weird as I really did nothing to fix this.
I was putting on new post rubbers and some plastics up at top of playfield which is tricky.
You have to have playfield slid back some and lifted to access the top wood screws with a screwdriver.
Thanks for your posts!
Consider this resolved.
$ 12.00
Siegecraft Electronics
Double Oak, TX
$ 17.00
New Tecumseth, ON
$ 45.00
LightAndTimeArt
$ 40.00
Arcade Arts
$ 48.00
Metal-Mods
$ 12,500.00
Great American Pinball
$ 9.00
Hdmike mods
$ 29.95
$ 9.95
$ 249.99
Id Rather Play Pinball
