(Topic ID: 265785)
Pharaoh no speech
By Mnbrian
4 months ago
  • 15 posts
  • 5 Pinsiders participating
  • Latest reply 3 months ago by Mnbrian
#1 4 months ago
My son just picked up a Williams Pharaoh. The background sounds work, but he is getting no speech. Do the speech rooms go bad often? What should we look at first? Thanks
#2 4 months ago
Manual is here if you don’t have one.
https://www.ipdb.org/files/1778/Williams_1981_Pharaoh_Manual.pdf
Learn how to get into test mode, there is a series for sound and voice. Go through the test before you do anything else.
Disconnect and reconnect all the wires and cables between the sound board and the driver and power boards. Make sure you do both ends. Do them one at a time and make sure the connections look ok, not corroded or burnt. Pay close attention to the ribbon cable between the sound and voice boards. Reseat them solidly.
There is also a potentiometer on the Voice board move it around And set it at 1/2 way.
Run your sound test again. Let us know the results.
#3 4 months ago
Thanks for the pdf. BK Just tried everything you mentioned, and during the test I only get sounds and no speech at all. Thanks
#4 4 months ago
Please post a pic of your voice board.
Next step would be to grab a logic probe and start digging into the board itself. I don't think the roms would be a primary suspect, but I'm not a board expert.
#5 4 months ago
Here she is.
#6 4 months ago
you are missing roms , contact me , i can help.
#7 4 months ago
Yep, missing those three little roms.
Easy and cheap fix thank goodness. Update us when you get them installed.
#8 4 months ago
Quoted from Mnbrian:
Here she is.[quoted image]
The speech board should be fully populated with ROMs - you need four! I would burn a set of four correct ROMs and install them. Then check and see where you are at.
#9 4 months ago
I do have all four speech ROMs, the picture was taken during inspection of the ROMs. If my ROMs are any good, who knows.
#10 4 months ago
also the sound rom must match the speech roms. ie it must be a pharaoh sound rom.
#11 4 months ago
Quoted from Astill:
This is one thing I haven't checked. Only one of the four ROMs was labeled Pharaoh. The other three, nothing. Would I get any speech at all with only one rom installed at a time?
#12 4 months ago
Does your black knight work correctly?
You could take some photos so you don’t put them in the wrong spot, but I would try those pharaoh roms in the bk speech board , in the pharaoh. Easy swap.
I would think that help determine if it’s the ph speech board or the roms.. ?
#13 4 months ago
That's what my son was thinking, but I'm a little apprehensive about messing with a machine that works fine. Might open a can of worms, with my luck.
#14 4 months ago
I have no stake in these but, bought one and it was great fix
http://pinballpcb.com/products/replacement-system-6-7-9-speech-board/
#15 3 months ago
Quoted from topkat:
This is the route we are going, fingers crossed.
$ 12.00
Siegecraft Electronics
$ 45.00
LightAndTimeArt
$ 17.00
$ 5.49
$ 5.00
Various Other Swag
$ 76.95
$ 32.00
$ 999.00
$ 132.00
$ 27.99
$ 128.00
$ 76.95
