I've been following this ever since you started this project. GREAT JOB!
I have a POTO and I have a problem I hope someone on here can chime in on and help me get the issue resolved.
My ball up-kicker wasn't quite getting the ball over the lip and into the shooter lane. It got progressively worse to where the ball would not come out at all. Just kept popping it up but with little 'oomph'. I decided today to put a new coil in to see if that was the problem, and apparently, it WAS! It now has the power to kick the ball out into the lane and works super in that regard. HOWEVER . . . when I started to play, the pin will not recognize that the 1st ball has drained, and it kicks up a new ball and never gets past Ball 1. You could play forever! And sometimes it now kicks up two balls. I'm sure I've messed something up while putting in the new coil. I know it was installed correctly and don't remember touching anything else. Anyone have any ideas?
Also, can someone confirm how many balls this pin uses? I have three in it right now.
Thanks!!!
Mike in Kentucky
