It looks very similar to your 2nd picture in your first post, they kind of look like they are sitting on one another almost. That switch is very flaky I had to play with mine a little when I got my game and even now it still doesn't always register. I can get pictures of whatever later if you still need.
Here is one I have completely torn down right now if you need reference pics... It looks like you are missing the metal ring around that lock assembly.
https://plus.google.com/photos/114677989241940608218/albums/5983853940833501777
Quoted from Choggard:Thanks, What does it look like with two balls in the kickout?
Mine "sit on each other" as well, I believe that is just how it works, it still should trigger the switch.
Seems to look the same as mine, from what I can tell from the photos. I don't have a multi-ball issue as far as I know. Bemmet is right, the second ball sits almost on top of the ball sitting on the VUK. This has never affected the ejection of the balls for me though. My game is the only POTO I have ever seen or played though, so I am not sure how much this helps.
If they are getting stuck then maybe it's the actual switch under the playfield that is the issue, not the metal trigger.
This page was printed from https://pinside.com/pinball/forum/topic/phantom-of-the-opera-picture-needed and we tried optimising it for printing. Some page elements may have been deliberately hidden.
