Hello Everyone!
YES I am perplexed. I have a TZ with no credit dots. The ONLY issue is the second button on the service switch (Volume down) does not register. The down volume switch is on the Orange Blue-wiring which as far as I can tell is a dedicated wire. The machine has a brand new Rottendog CPU board.
I REPLACED the entire service bank including adding in the ground line but I get the exact same results. All other switches on the service bank worked before and after the replacement. I have continuity between the service switch and the Coin door interface board and between the board and the connector to the new CPU board. I have also jumped this connector and it registers continuity but fails to activate the switch. In SWITCH TEST Mode the button does not register (Volume up registers fine). I am assuming the problem is upstream of the CPU board since there are no other errors. Would the issue be somewhere on the Power Board? I am not the best at reading schematics but I believe that is where it goes next. IS there a dedicated transistor or other component on one of the other boards? Feel free to offer suggestions!
