Trying to wire coils in a machine and the pd16 board fuse blows every time on startup, but only when a coil is wired up. I checked the coil to see if it was shorted but it reads fine. I removed all other coils to narrow down the problem. Again, when a coil is not wired up, then the board turns on and the fuse doesn't blow. It is only when the coil is wired that the fuse blows.
