Does somebody has experience with the PC power support unit inside a WOZ, Model SPI ATX-400PN?
The PC in mine WOZ does not boot anymore. Both fans of the power supply and the Intel CPU on the motherboard are dead. In case I push the reset buton, both fans are starting to run for a very short moment. Then both stop and start to run again for a very short moment. And so on.
I've disconnected the power supply and measured the outputs. All signals showing 0V. Even after having connected the power_on signal with the green cable on the ATX power connector to ground.
It seems to me the power support unit is broken, though the signs of some life after pressing the reset button is a bit strange.
Does somebody have experience with this?
Where can I buy this PSU, model SPI ATX-400PN? The are not on stock with JJP.
I notified JIP a few easy ago. This customer service seems a bit show.
Thanks, Erik
