I’ve had this game for over 10 years now, but last week in the middle of a game, my PZ reset for the 1st time ever. Note that this is a true HUO game, with virtually no wear or use on it, other than the driver brd replaced by the previous owner (she sold it to me because the PZ did not work again- batteries turned out to be dead).
When I turned it back on, I got the “fuse F114/F115 failed” message after the Captain turned his head from right to left; head will not turn back to the right. Checked all fuses- OK. Thinking it might be the opto brd on the head, I removed the power to it and the power to the head itself- same thing.
LED's 1, 2 and 3 will not light on the driver brd. TP1 gives 14.96. TP2 is OK. TP3 should be 12; gives less than 1. TP6 gives 16.3; TP7 is OK; TP8 should be 50 (says so on brd), but gives 80.
AC voltage at J101 pins 4 & 7 is OK- gives 14. J101 pins 5 & 6 gives 14. J101 pin 6 to fuse 114 gives 14.
Any ideas? Driver board NG again? On the CPU, the LED’s do the correct test sequence (top & bottom turn on, top goes off, center blinks rapidly]. I put a remote battery on the machine running to the coin box when I first got it.
