(Topic ID: 278849)
Parts
By Sparky18
1 year ago
  • 20 posts
  • 11 Pinsiders participating
  • Latest reply 1 year ago by Sparky18
#1 1 year ago
I’m a newbie. I have a eightball deluxe. Where should I look for the best parts / circuit boards?
#2 1 year ago
Quoted from Sparky18:
https://pinside.com/pinball/forum/topic/rottendog-s-demise-where-to-get-boards-now-
Pinballlife
MarcoSpecialities
Ebay
Little shop of games
Pinside ads.
#3 1 year ago
Hit up the Eight Ball Deluxe owners club thread: https://pinside.com/pinball/forum/topic/eight-ball-deluxe-owner-club-guests-welcome-as-well
#5 1 year ago
Are you experiencing a particular problem with your EBD? Buying new boards at random is a pretty expensive thing to do if you don't need them.
#6 1 year ago
Not sure if it's Covid related but I've noticed replacement boards are showing up out of stock lately. As Evan says, what is the problem you are having? What board are you looking for and why?
#7 1 year ago
2 problems . Once the ball drains, it won’t eject. And one of the pins on a plug-in is broke off on a circuit board.
#8 1 year ago
Do you have a multimeter? If not, you should buy one before buying anything else. Broken pins can be fixed for a fraction of the cost of a board.
Close up pictures are always the best for such issue. You will need a multimeter to troubleshoot issues on your machine.
Welcome to the pinball hobby!
#9 1 year ago
That might be one problem.
Some of the header pins are removed, it helps identify where and which direction to plug a connector in. So his might be normal. Which pin is it, on which board? You can find schematics for your game at ipdb.org and there will be a picture of the board in there somewhere with connector names like J1, J2, etc.
Or, it's possible that you do have a broken pin, and that pin is for the trough switch, in which case you can save yourself a few hundred bucks by just getting a soldering iron, a solder sucker to remove old solder, and a rail of header pins for a few cents.
And if you have no interest in DIY, and would rather just spend the $ and swap boards, that's cool too. But it's definitely in your interest to identify the exact problem first before doing that, and make sure that swapping boards will fix it.
#10 1 year ago
Thanks Roamin and EvanDickson!!! I will invest in a multimeter and run with your advice. Thx to you both!! And will try to post a pic
#11 1 year ago
Update your location. Maybe some is local that can help.
#12 1 year ago
Well apparently I have a much bigger problem. In addition to the drain ball ejector not working , the 8 ball bonus pocket won’t eject either, along with 3x 4x 5x pop-ups. The #9 pin on plug J1 looks like it may supposed to be missing. Geez I need lots of help!!!!!
#13 1 year ago
Good hands on learning experience. We're here to help you.
#14 1 year ago
It seams it all went wrong at once. Does that infer board problem?
#15 1 year ago
Do they fire in self test? Have you purchased a multimeter? Is there power at the coils? Don't let this discourage you, I consider myself a "newb" and have learned ALOT by reading thru the forums and asking for help from fellow pinsiders who are more than happy to help out. You will get it fixed, of that I have no doubt.
#16 1 year ago
Possible short/bad connect with a wire in the plug. How do I fix? Or is it possible to buy a new plug?
#17 1 year ago
Everything starting working briefly
#18 1 year ago
IDC plug, yuck. Replace it with a discrete crimp connector:
Connector:
https://www.greatplainselectronics.com/proddetail.asp?prod=CS100-28-LR
Pins and key:
https://www.greatplainselectronics.com/products.asp?cat=73
And inspect header's solder joints on bottom side of board.
#19 1 year ago
Thx For the help
#20 1 year ago
Can anyone recommend a person who can do service on the pinball if needed ? 41094 zip code
