Quoted from mac622:Anyone considering this project should do it! It was a great / fun project that only took about 1.5-2 hours to finish and was great for further developing the soldering skills. Because Ed at GPE is a regular contributor here on Pinside and a good guy I bought the parts from him instead of Mouser. After I finish up my FH I'm going to tackle one of the blank boards next
Here is the finished board at work. I left the game on for about 8 hours and then played a bunch of games and no issues.
Mac622 and Pin_guy:
Have either of you noticed that the RTC clock runs fast? Really fast...
My build was also fun and something everyone, who is looking to improve their soldering skills, should do. Anyway, the board started without a hitch, I set the clock, and played many games. I then noticed that 90 seconds would pass for every minute. Ugh...
I purchased a quality crystal/Xtal (Citizen, 32.768KHz w/ 12.5pF) and thought there might be lots of "noise" from the board. So I brought out the trusty oscilloscope. The trace at U9 pin 70 was pretty; no noise. So, I compared the clock/signal from the new "Two Bits" and the original WPC board. Sure enough, the Two Bits board runs fast. You can see in the pictures there's 1.5 waveforms to the original's singular/full waveform. There's no way my crystal could be that far off!!!
OK, referring to our trusty WPC schematic, R91 is 22MΩ and R92 is 470KΩ. Looking at the original board, you can clearly see a <b>Red-Red-Blue</b> (gold tolerance) banded resistor (22M&Omega, and a Yellow-Violet-Yellow (gold tolerance) banded resistor (470K&Omega
But, on my Two Bits board, R91 is <b>Red-Red-Green (2.2M&Omega</b> R92 is fine. Looking at the (amazing) initial photos from Pin_Guy, his photos match my board.
As for C28, C29, and C30, I can clearly see the color coded radial capacitors on the original board; they match the schematic (100pF, 22pF, and 22pF). The Two Bits board, I can see "220" on two <i>chicklet</i> capacitors, 22pF at C29 & C30. As for C28, I can only see "1 ( ) 1K". The "( )" is an odd encoding, but I'll interpret that to be 10 multiplied by 10, 100pF with "K" tolerance. Anyway, I'm pretty confident that the capacitors are right in the timing circuit, Only that R91 is wrong.
Thoughts...
