TWOBITS.COM
4418 PACK SADDLE PASS
AUSTIN TX 78745
512-447-8888
[email protected]
HTTP://WWW.TWOBITS.COM
WPC MPU BOARD BILL OF MATERIALS
WPC2A_1.PCB Bill of Material Summary
DESCRIPTION QUAN. COMPONENT DESIGNATOR(S)
----- ALL RESISTORS 1/4W UNLESS OTHERWISE SPECIFIED
ZERO OHM JUMPER 9 W1,W4,W7,W13,W14,W15,W16,W17
W18
470 OHM 9 R5,R6,R7,R8,R12,R13,R87,R88
R89
1K 25 R43,R44,R45,R46,R47,R48,R49,R50
R51,R53,R55,R57,R59,R61,R63,R65
R67,R68,R69,R70,R71,R72,R73,R74
R84
1.2K 16 R52,R54,R56,R58,R60,R62,R64,R66
R75,R77,R78,R79,R80,R82
1.5K 6 R1,R2,R3,R4,R93,R97
1.5K 1/8 WATT 1 R96
10K 29 R14,R15,R16,R17,R18,R19,R20,R21,R22
R27,R28,R29,R30,R31,R32,R33,R34,R35
R36,R3,R38,R39,R40,R41,R42,R86,R90
R94,R98
470K 1 R92
1M 2 R95,R99
2.2M 1 R91
4.7K x 9 BUS RES NET 1 SIP1
----- ALL CAPACITORS AXIAL LEADS, X7R OR Z5U UNLESS OTHERWISE SPECIFIED
22pF AX CONF 4 C2,C29,C30,C34
100pF AX CONF 1 C28
470pF AX CONF 24 C3,C4,C5,C6,C7,C8,C9,C10,C11,C12,C13
C14,C15,C16,C17,C18,C19,C20,C21,C22
C23,C24,C25,C26
1000pF AX CONF 2 C32,C33
.022uF AX CONF 1 C50
.047uF AX CONF 1 C27
.1uF AX CONF BYP CAP 16 B1,B2,B3,B4,B,B6,B7,B8,B9,B10,B11,B12
B13,B14,B15,B16
100uF 16V AX AL ELEC 1 C31
FILTER CHOKE 4.7uH 1 L1
32.768KHz FORK XTAL 1 X1
8MHz CRYSTAL 1 X2
1N4148 DIODE 17 D2,D3,D4,D5,D6,D7,D8,D9,D10,D11,D12
D13,D14,D15,D16,D17,D18
1N5817 DIODE 2 D1,D25
RED LED, T1 (3mm) 3 D19,D20,D21
2N3904 NPN BIP TRANS 1 Q1
SN74LS244N 3-ST DVR 3 U1,U2,U7
SN74LS245N OCT BUS XCV 1 U3
68B09EP PROCESSOR 1 U4
SN74LS14N HEX SCH TRG 1 U5
GAME ROM, 27C040 1 U6
M48Z58Y-70PC1 ZPRAM 1 U8
WPC CUST 5410-12426-01 1 U9
MC34064 SUPERVISOR 1 U10
SN74LS240N OCT INV DVR 4 U11,U12,U13,U15
SN74LS374N OCT LATCH 1 U14
LM339N QUAD COMPAR 4 U16,U17,U18,U19
ULN2803 8-CH DARL DVR 1 U20
MC14584BCP HEX SCH TGR 1 U21
40-PIN LP SOCKET 1 U4A
32-PIN LP SOCKET 1 U6A
28-PIN LP SOCKET 1 U8A
84-PIN PLCC SOCKET 1 U9A
14-PIN LP SOCKET 4 U16A,U17A,U18A,U19A
18-PIN LP SOCKET 1 U20A
26-PIN .100 DUAL HEA 2 J201,J204
34-PIN .100 DUAL HEA 2 J202,J211
-----ALL HEADERS FRICTION LOCK TYPE
12-PIN SER KK .100 HDR 1 J205
9-PIN SER KK .100 HDR 4 J206,J207,J208,J209
7-PIN SERIES KK .156 1 J210
8-PIN SER KK .100 HDR 1 J212
TRIPLE AA BATT HOLDR 1 BP1
MOUNTING HDW FOR X2 1 ---- USE MOUSER PART NO. 749-CI-192-050-3
PARTS NOT USED
NO PART ON ORIG PCB 1 C1
3-PIN SER KK .100 HDR 1 J203
ZERO OHM JUMPERS 9 W2,W3,W5,W6,W8,W9,W10,W11,W12
