About 3 years ago I picked up a Paragon from a guy who had it since 1985. Overall it was in pretty good shape; the cabinet had faded a bit but not too much, little wear on the playfield, and backglass in perfect shape. He also put in a new Alltek MPU board. The only major problem was the inserts cupping, the large "PARAGON" inserts being the worst.
I decided to fill them with Varathane using a pipette. Bad idea. I waited over 2 months for it to cure but the stuff remained soft and developed cracks. I took a plastic razor and actually peeled the varathane off of the inserts. Unfortunately it took a lot of the ink with it. At this point I swore to never use water-based stuff again.
Soooooo, I popped out all of the inserts with a heat gun and several dowel sizes, leveling them in the process and some slight sanding to remove the remaining ink. The inserts looked really nice, and the white ones were now bright white instead of yellow. The only problem was no ink.
I bought insert decals off of ebay, but was not happy with them at all. I decided to roll my own. I made laser water slide decals. My wife who is a brilliant graphic designer found the font and measured the inserts so the text and the decal would line up exactly with the inserts. (If anyone wants the Illustrator and pdf files let me know.)
Using Vid1900's playfield restoration thread as a guide, I sprayed a light coat of clear to lock in the wood and provide a surface for the decals and small touchups. A few days later, I applied the decals and my wife did the touchups. I decided to spray the reflective areas on the game as Vid had mentioned. This was the first time I used Frisket paper and it certainly kicks ass! It was the first time I used an airbrush too.
I used spraymax 2K clear in a can, did a few mist coats, another couple slightly heavier, and then the final coats.
I'm really happy with the way it came out. I also want to thank Vid1900 for sharing his knowledge and experience...and replying to my emails. I greatly appreciate it.
Now the playfield looks so good, I HAVE to redo the cabinet lol.
