Was chasing down a problem on my Paragon and created another. Was losing power to parts of the playfield and noticed some loose connections on J1 of my solenoid driver board. I replaced the connectors and removed the board to clean up any cold solder joints.
When I replaced the board the game starts up, boots correctly but I have no displays. Also no bumpers or slingshots are active during play. When I place in test mode I have nothing in displays. When I go into solenoid test all bumpers and slingshots fire. Any idea what I did here? Fuses seem to be fine.
Also swapped in the solenoid driver from Silverbsll and same symptoms.
Appreciate the help!
