(Topic ID: 69394)
Paragon Club... the Valley of Demons
By schwarz
10 years ago
  • 1,901 posts
  • 255 Pinsiders participating
  • Latest reply 2 hours ago by Deadlander
  • Topic is favorited by 111 Pinsiders
12 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 1,901 posts in this topic. You are on page 19 of 39.
#901 3 years ago
Quoted from guitarded:
Swinks makes a replacement head, now...
don't know where I'd look for the whole assembly right now, though?
Unfortunately my right flipper and left sling arm was removed. Game was too hard I guess. A lot of extra posts on the playfield as well.
#902 3 years ago
Quoted from orangegsx:
Last time I was able to source original NOS heads, they came from a repair Tech in BC. Had to be on page 25+ of a search for Bally parts.
My advice is to maybe start calling around to repair techs / operators who might have a stash of OEM Bally parts / castoffs?
#903 3 years ago
Yep just got 4 of them in today. Looks like they are 3D printed and seem to work very well.
#904 3 years ago
Quoted from wrd1972_PinDoc:
yes these are solid nylon laser sintered 3d printed, much stronger than home printing
here is a link to my reproduction parts via Shapeways - about 14 items down the list
https://www.shapeways.com/marketplace?q=swinksreproduction&sort=newest
hope it helps
#905 3 years ago
Planetary Pinball has the head in stock for $4, I just ordered a half dozen. If you still need the pivot, PM me and let me know which side, I probably have a used one.
#906 3 years ago
I just went from 5 ball to 3 ball. What do you guys have your free games set at?
#907 3 years ago
Quoted from Ballypalooza:
I have one set at 40 and another at 90 or so. Keepin' them credits up.
#908 3 years ago
I have my Paragon set up to 3 balls, all settings conservative except for SW 24 because I dont like the Paragon saucer to scan. One extra ball can be earned per ball in play, then 25k or 50k points added afterwards for 2nd earned extra ball or special.
Tough game, but I love the challenge. I may eventually buy the weebly board so I can add the Million digit.
#909 3 years ago
I have mine on 3 ball. The PARAGON scans, and the lit letter is awarded at the saucer and upon hitting an inline drop. I have the first free game at 200k and the second at 450k, which is hard enough that I need to add credits every once in a while.
My playfield is a little worn, and has cupped inserts as many machines of this era do, but I have a playfield protector that fixes that. I am a fan of pf protectors in these instances since I don’t have the skills needed to fix it any other way
#910 3 years ago
Congrats on finishing the CPR restoration- looks amazing. I'm hoping to one day (eventually) go that route for my own machine but a project of that magnitude is definitely still outside my own comfort zone/skill set.
In the meantime though, the plastic on my upper-left pop bumper split apart over the weekend. What's the best way to go about replacing? They were already a little (ok, REALLY) worn so I'm thinking a rebuild is in order. (Images attached)
I'm browsing Marco specialty now but they don't seem to offer any bumper rebuild kits- would I notice any improvement if I just replace the plastic skirt, base, and body? The caps are still fine.
They bumpers still have a strong "pop" when they are triggered too so I don't think I'd need to replace the solenoid or whatever does the actual popping, but what do you guys think is the best course of action here?
Also I have yet to lift up the playfield too so I really don't have any idea of the condition of the wiring, etc underneath...
(man I hope this doesn't end up being a can of worms...)
popz-1 (resized).jpgpopz-1 (resized).jpgpopz-2 (resized).jpgpopz-2 (resized).jpg
#911 3 years ago
Quoted from somenerd:
[quoted image][quoted image]
Rebuilding bally ss pop bumpers was the first “serious” maintenance I ever attempted and it gave me confidence to attempt more complicated things. I followed Vid1900’s guide and everything went smoothly. It was my first attempts at desoldering and resoldering and they are still popping like mad 3 years later!
If you go that route I recommend replacing the lamp sockets with wedge-based, this will eliminate the flakiness from all the vibration they take.
I think I got my rebuild kits from Marco and it had everything that should be replaced, except the lamp sockets which you would have to add to the kit. Good luck! Paragon is a great game.
#912 3 years ago
Update... I opened up my game to remove the broken bumper plastic. Unscrewed the pair of tiny screws, took out the broken chunk. Easy peasy. I then lifted the playfield to try and figure out how to go about swapping out some of the parts I'd need to access from underneath.
I didn't trust the "stand" (a long thin piece of flimsy-looking metal that came to a point and didn't appear to latch into/onto anywhere), so I just ended up sliding the playfield back into place without ever propping it up with anything but my hands for a few moments.
I put the glass back on and started a game to see if it still worked fine, and... the lower-left flipper is now unresponsive to the flipper button. The upper-left mini flipper works just fine. So now I gotta troubleshoot what I could've possibly messed up in those moments. yeeesh HERE WE GO
#913 3 years ago
I cut two lengths of wood for propping up my Paragon PF. It's too unweildy to rely on the factory bar.
#914 3 years ago
Does someone make great looking instruction cards??
#916 3 years ago
I got these from UPKICK and really like them. I also got some coin door inserts. https://pinside.com/pinball/market/shops/1256-upkick-pinball/04020-paragon-coin-door-inserts-
#917 3 years ago
Connector day... its never fun, but it always needs to be done. I repinned all 3 of the connectors on the new Bigdaddy power supply board.
I have a known working Power Supply, MPU and SDB in this machine. On my first power up it seems like everything is working except for playfield solenoids. They dont fire after the game boots and they dont fire in gameplay either...
Where would you look first?
20210322_131943 (resized).jpg20210322_131943 (resized).jpg20210322_131948 (resized).jpg20210322_131948 (resized).jpg20210322_132756 (resized).jpg20210322_132756 (resized).jpg
#918 3 years ago
Quoted from FLASHBALL:
1 amp fuse on the underside of the playfield. Check this first.
Confirm all your voltages at the rectifier & driver board too.
#919 3 years ago
Bingo!!! Paragon #2 is up and running!
Thanks! djblouw
#920 3 years ago
Bally Rectifier board day. These are kind of a PITA to remove and reinstall. But I love the BigDaddy replacement as it has the voltage LEDs and also numbers on the back of the board for easy reinstalling.
This 3rd Paragon is going to be the worst of the bunch. Despite having to do all of the normal stuff to get a game working... a mouse took up residence inside it and chewed and frayed several wires inside the backbox. Mostly on the inside of the door it seems like. Not looking forward to that.
Wish me luck.
#projectPARAGON #StevensRestoration
20210323_135132 (resized).jpg20210323_135132 (resized).jpg20210323_140403 (resized).jpg20210323_140403 (resized).jpg
Screenshot_20210323-140700_Chrome (resized).jpgScreenshot_20210323-140700_Chrome (resized).jpg
#921 3 years ago
Quoted from Gort:
Thanks! We're glad you like them. We love making pins look great!
paragon1 (resized).jpegparagon1 (resized).jpegparagon2 (resized).jpgparagon2 (resized).jpgparagon3 (resized).jpgparagon3 (resized).jpg
#922 3 years ago
This may be a problem with other early Ballys. But since I recently joined the club, I thought I'd ask my question here.
The first drop target in the Valley of the Demons occasionally sticks up too far and is pretty much impossible to knock down. It doesn't happen on every ball, but when it happens, I just have to focus on getting the super bonus. And then the target resets itself properly on the next ball.
Can someone help me out?
#923 3 years ago
Worn parts on the inline target, next time it happens pull the playfield up and see if the pick arm on the drop has moved too far up in its slot.
#924 3 years ago
Quoted from slochar:
Yeah, probably the P-7939-1 (or 7939-?) bracket is broken. It is an obsolete part, but some are being 3D printed. Others (me included) made my own out of angle steel.
https://www.shapeways.com/product/JQGC7NU2N/nut-spring-bracket-p-7939-1-left-modded
#925 3 years ago
Owned a Paragon for a couple years now - my first pin. Pretty much unmolested overall, with heavy play field wear and typ cab fading. I have a CPR play field that’ll get swapped out sometime this summer once I’m done shopping the elec and mechs
Still on the fence for refinishing the cab while I have it apart. It’s the right thing to do, but unsure if it’ll add too much to the project that it’ll take a summer project into a two summer ordeal
#926 3 years ago
Joining the club soon. Getting delivered this Saturday locally. Thanks Ned! Got on CPR’s list for playfield and will restore the cabinet. Playfield not horrible by any means. New Alltek board and all LEDs.
61F91F95-98A4-438F-AC3C-45ADFE8063D3 (resized).jpeg61F91F95-98A4-438F-AC3C-45ADFE8063D3 (resized).jpeg6579C2F0-1977-4630-A6AE-1885F1FB639A (resized).jpeg6579C2F0-1977-4630-A6AE-1885F1FB639A (resized).jpegB75492E5-2DBB-495F-866D-59D390313E5E (resized).jpegB75492E5-2DBB-495F-866D-59D390313E5E (resized).jpegDA921F68-D052-44CF-808B-E8A59CC2E6D9 (resized).jpegDA921F68-D052-44CF-808B-E8A59CC2E6D9 (resized).jpegE6175269-0CA2-479F-A2A6-0EB7780C3A33 (resized).jpegE6175269-0CA2-479F-A2A6-0EB7780C3A33 (resized).jpeg18FD3BF0-3CA8-4C07-9943-996D0F661BBD (resized).jpeg18FD3BF0-3CA8-4C07-9943-996D0F661BBD (resized).jpegEC9B0B4B-7DDC-46F2-89FC-036A605BF2D1 (resized).jpegEC9B0B4B-7DDC-46F2-89FC-036A605BF2D1 (resized).jpeg
#927 3 years ago
Quoted from JethroP:
I finally got to look at this today. I didn't see any broken bracket. I attached the picture of the bank (upside down). I hope that someone can spot a problem right away. What I did do is replace the spring on the first drop target. That seemed to fix the issue. But then the problem happened again on a good game. I racked up a decent super bonus, and the first drop target was reset too high again and wouldn't budge. Crap.
I'm kind of lost on why the bracket could be the issue, and if that could still be a factor of my problem.
#928 3 years ago
Quoted from BallyKISS1978:
Congrats and nice apron cards! We have coin door inserts too.
#929 3 years ago
Quoted from cadmium:
Congrats and nice apron cards! We have coin door inserts too.[quoted image]
Nice!! Do you have a griffin facing the other way so they both face to the center insert?
#930 3 years ago
Congrats on the acquisition! That's a really nice-looking machine; that playfield especially. Since I've got mine I've played it damn near close to every day, and I'm still so happy to have one I can call my own. Hoping you enjoy yours just as much.
Sharing an update to my previous posts:
After one of my pop bumper plastics completely broke apart a month or two ago, I ended up calling a local tech who really fixed things up for me quite a bit (Ken at Northeast Pinball; such a great guy).
Added 4 brand new pop bumpers, upgraded the lighting to LEDs (with a couple *tasteful* color accents) and added an Alltek board, replaced the malfunctioning credits/match display with a PinScore, and got a fresh wax and new posts & rubbers. He also added a lock to the door and replaced the old and overly-sensitive flipper buttons. It's playing like a brand new machine and was definitely worth the investment. I also bought some replacement plastics on eBay and swapped out the mangled piece featuring the spear-dude on the upper-left corner.
While the playfield is still worn in spots and the backglass has unfortunately flaked a little more at the bottom, those are (relatively) minor cosmetics in the grand scheme of things. Would love to go with a CPR playfield eventually, but after dropping the coin on these upgrades that's probably a ways away.
paragon_led_full (resized).jpgparagon_led_full (resized).jpgparagon_led_pf1 (resized).jpgparagon_led_pf1 (resized).jpgpin_group (resized).jpgpin_group (resized).jpg
#931 3 years ago
While the playfield is still worn in spots and the backglass has unfortunately flaked a little more at the bottom, those are (relatively) minor cosmetics in the grand scheme of things. Would love to go with a CPR playfield eventually, but after dropping the coin on these upgrades that's probably a ways away. [quoted image][quoted image][quoted image]
Forget the CPR. Your playfield looks really nice. As long as it plays well Id forget about the cosmetics and just enjoy it. I know a guy with a Frontier that has a 6 or 7 inch worn circle of bare wood right in the center. He has a CPR ready to put in but cant bring himself to start because other than missing some of the artwork the game plays fantastic.
Its pinball, enjoy it.
#932 3 years ago
Quoted from freejack1971:
I would turn the first three studs around... the last one looks correct.
#933 3 years ago
Just finished my cpr playfield swap, every star rollover filled to the brim with clear, pop bumper yoke holes had to be drilled out-lights holes as well, paintjob seems off to the right, I will always look for a mirco over cpr from now on.
#934 3 years ago
Quoted from BallyKISS1978:Nice!! Do you have a griffin facing the other way so they both face to the center insert?
They can face them anyway you want.
#935 3 years ago
I got ahead of myself replacing playfield sockets. Can someone please give me pictures showing were these two red and blue wires go? They are behind the three drop target mech.
IMG_1512 (resized).JPGIMG_1512 (resized).JPGIMG_1513 (resized).JPGIMG_1513 (resized).JPG
#936 2 years ago
Anyone have a picture of this connector. I was trying to repin it, but got confused on the location of a wire. It's J3 on the driver board thanks.
20210507_192235 (resized).jpg20210507_192235 (resized).jpg20210507_192247 (resized).jpg20210507_192247 (resized).jpg
#937 2 years ago
Quoted from Coolpinballdino:
34A8A179-1D2D-4F4B-9F9B-3AC8FE2A98EA (resized).jpeg34A8A179-1D2D-4F4B-9F9B-3AC8FE2A98EA (resized).jpeg
#938 2 years ago
Always best practice to use the manual when you can. Never know when a previous Operator did something fishy.
Here's a picture of J3 from the manual and the wire color code.
USER_SCOPED_TEMP_DATA_orca-image--936717120 (resized).jpegUSER_SCOPED_TEMP_DATA_orca-image--936717120 (resized).jpeg
*note* pin 25 and pin 13 is the same wire and jumps from one to the other.
#939 2 years ago
I personally like to see what colors the wires have become on someone else's game so that I can determine whether something is supposed to be red, orange or yellow. I envy the folks with perfect color vision.
#940 2 years ago
Quoted from newovad:
...and a clean wire harness
#941 2 years ago
Quoted from emsrph:
That first wire is “white”. No way in hell it is white even if I clean it.
#942 2 years ago
It looks like your white has darkened a little, that's all. The wires with white (3, 10, 15, 21, 24) show the same shade of "white" by comparison. More like tan. Insulations age differently depending upon the environment where they've been.
#943 2 years ago
Whaddaya reckon a nice restore paragon is going for these days with a clear coated PF?
#944 2 years ago
Quoted from scruffypinball:
Oddly, Paragon is the only pinball machine currently that has gone down in price. So much so, that you have to give them away. You have my address and I have your PayPal. I'll pay for shipping and you can send it my way.
#945 2 years ago
At least 3 griffins and a beard
12
#946 2 years ago
In the club!
#947 2 years ago
Today I saw a post through Facebook from a guy who'd made a new processor type thing for Paragon so the game plays differently (enhanced rules) and has improved (different) sounds... does anyone know about it? I can't seem to find the Facebook thing again!!
#948 2 years ago
Does the above work?
Is that your actual game? Playfield looks amazing!!
#949 2 years ago
Thanks- good perspective! I have been enjoying it, and I'll try and worry less about the cosmetics now that everything's in good working order.
#950 2 years ago
I add an extra orange wire to J3 pin 1.
+12 volts unreg. from power supply.
Basically an extra support for J3 pin 12.
3,600 (OBO)
Mountainside, NJ
$ 69.00
Pinball Pimp
$ 69.00
Pinball Pimp
4,200 (OBO)
Springfield, MO
$ 44.99
Pinball Shark
$ 10.95
Retro Electro Designs
$ 18.95
Trade
Machine - For Trade
Munster, IN
$ 9.00
Cabinet Parts
Third Coast Pinball
Metal-Mods
Playfield - Plastics
$ 55.00
Displays
PinballSolutions.eu
$ 179.00
Pinball Pimp
This page was printed from https://pinside.com/pinball/forum/topic/paragon-club-enter-the-valley-of-demons/page/19 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
