Hi malachi88
great, the pin runs 100 %.
The following is theory - not needed, maybe of interest:
The Score-Reel-Coil gets current and pulls, the plunger travels and at the end of travel a notch on the plunger hooks-in behind a tooth on the Score-Reel. Lets say this takes time "0.6 second".
A "Bulls eye shot / heavy shot" closes the switch (for 10 points) on the playfield for (lets say) "0.6 second".
A "Grace shot" closes the switch (for 10 points) on the playfield for (lets say) "0.3 second".
The "Closing the switch on the playfield" lets the 10 point relay pull. And the 10 point relay (by pulling) closes a switch (on the 10 point relay) -> the "Coil on the Score-Reel" gets current.
WITHOUT "Self Hold Switch on 10 point relay": The 10 point relay would quit pulling at the time the ball on the playfield moves away from the playfield switch.
So a "Grace shot" would only let current flow to the "coil on 10 point Score-Reel" for "0.3 second" - not enough time for the plunger / notch to travel - 10 points would not be given.
For this problem the manufacturer invented the "Self Hold Switch on 10 point Relay".
When the 10 point relay starts pulling: (It closes the switch for the Score-Reel and) it closes its "Self Hold Switch" - the 10 point relay stays pulling for a long time (the ball on the playfield can roll away) the 10 point relay stays pulling until the plunger on the Score-Reel has completed its travel -> the End of Stroke Switch on the Score-Wheel is opened by the travelling plunger. And this opens the circuitry of the "Self Hold circuitry on 10 point relay" -> 10 point relay quits pulling and so (opening the switch): the "Coil on the Score-Reel" ALSO looses current.
If You want to see a JPG -> https://pinside.com/pinball/forum/topic/reading-gottlieb-schematics -> my post-39. Greetings Rolf
