Hi all.
My DW is displaying this error during the display test and has vertical lines across the right side if the screen.
What components should I be targeting for replacement?
Thanks for any advice.
try a new ribbon cable if it still does it, the ram on the display board is likely bad. If it still does it with a new RAM.... it gets a bit more complex. There are a TON of ttl chips on that display board to check out.
Reseat the ribbon cables, and order a new set if yours are original. If you can't replace the RAM yourself, I can give you a couple recommendations for technicians in your country who can help.
I swapped the ribbon cable for a known working one - same issue. So I will order a new RAM chip. I swapped a working display driver board in and this eliminated the issue, so definitely a problem with the board.
Out of interest, I also pulled a different display driver board out of one of my project machines. This one displays a couple of lines on the right side of the screen and fails the display test with a RAM address error. I assume this one also needs U24 to be replaced?
Also out of interest, I put both boards into my FT, which has a colour DMD. The issues were exactly the same on FT, and the display was greyscale instead of colour. This is expected I suppose, since the colour DMD still uses the original ROMs for display data.
John, I would appreciate those recommendations also
This page was printed from https://pinside.com/pinball/forum/topic/paging-error-on-wpc-dmd and we tried optimising it for printing. Some page elements may have been deliberately hidden.
