Cool! C2-26-800 is also what I came up with. THANK YOU for verifying connecting the two coil wire together would blow the fuse...I kinda figured such (haven't worked on one of these for *gulp* 35+ years).
I'm slowly kind of starting to understand the schematic...I think / hope.
So, next problem. The machine does turn on (yippie), kind of even plays, kind of. Currently however it appears there are 3 coils constantly energized. The Match Unit, the One Point Relay and the 100 Point Relay.
Based on the schematic, if in fact I'm figuring it out, the Match Unit coil is powered through the One Point Relay (E 15), which is powered by the #1, #3, #4 & #5, Bumpers, the Kicker Switch, the Stand Up switch, and the 1-PT D.U. EOS Switch (C 15/16). Would I 'probably' be correct that there's a set of contacts on one of these relays that's either "welded" closed, or out of adjustment and staying closed, causing this? (the 1-PT D.U. EOS Switch has me a bit confused. , it looks like the circuit would go through it AND the One Point Relay, to power the One Point Relay coil).
any ideas?
