Quoted from Tonup69:Purple X - light is on when drum units are at zero or not at zero.
Green X - light is off unless 1) impulse-A is moved to close the switch AND the drum units are not all at zero.
Blue X - light is on when drum units are not at zero, but off if all are at zero.
Still trying to figure out what your observations mean....
The light should be on at all times when connected to the purple X - and you saw that...the state of the drum unit zero switches shouldn't matter.
Your result at the green X is confusing me. I think the light should only come on when the make/break switch on the reset relay changes state. That's when your test lead is effectively connected to the yellow wire through that switch. I don't know why the impulse-A and drum unit switches are affecting it, unless the voltage from the yellow wire is coming the other direction through the impulse-A switch and the 10pt D.U. open at zero switch....which it could do if your O-W wire was shorted to the yellow wire.
I think those light bulb results would make sense if you had a short from the yellow wire to the left side of the 10pt coil. That's the same O-W wire that you jumpered earlier. Is the 10 pt coil locked on the whole time you're doing these tests, or have you been using that jumper in place of the original O-W wire?
Hopefully, this machine isn't too far away from you....
