I'm sorry if I confused the issue using the word "hot". dgAmpGuy is right, since we're talking about AC from a transformer, there's not really a ground, just a return, and so everything is relative to some reference point. So let's take your light bulb tester (a handy tool on EM's...glad you made that). You could use a meter as well set to AC voltage, but the lights will work just as well since we're just looking for the lights to be on or off. The important thing to remember is that if you clip one side of your lights to the right lug of the 10pt coil (which is essentially the BLACK wire), then any voltage we're talking about is relative to that BLACK wire....so let's take that as our reference.
If you then hook the other lead of your test bulbs to the YELLOW wire (where the purple "X" is), your bulb will always light because you're putting 24V across the bulb. If your lead is connected anywhere else, and the light comes on, it means that you have a connection to the YELLOW wire though whatever switches are involved....that is, those switches between the YELLOW wire and wherever your test lead is connected are closed.
Hooking the other lead of your tester to where the green or blue "X"'s are should be more informative:
- If you're hooked to the green "X", the light should come on when the reset relay make/break switch changes state from how it's drawn. (That is, the lower switch on the schematic is closed)
- If you're hooked to the blue "X", the light should come on when both the reset relay make/break lower switch is closed, AND the impulse switch is closed. So during reset, as the score motor turns, the light should rapidly blink on and off as that impulse switch A opens and closes. Once the reset is finished, the bulb should be off as both the reset make/break and impulse switches are open.
So I'm curious to see - setting all the drum units to zero and turning on the game - if you connect the other clip of your bulb tester to anywhere along the B-BLU wire (where the blue "X" is), does the light come on? It shouldn't. At that point, the reset relay make/break switch should be open, as shown. Also, if the score motor is in the home position, the impulse A switch should also be open. Your light should only come on if those two switches are both closed. (Remember, that's assuming the other lead of your light tester is attached to the BLACK wire.)
I hope this wasn't talking down to anyone - just wanted to make sure we're all talking about the same thing.
