(Topic ID: 303950)
P2000 SW ep1 issue
By Nihonmasa
2 years ago
  • 7 posts
  • 4 Pinsiders participating
  • Latest reply 2 years ago by Nihonmasa
#1 2 years ago
Hi guys,
I am trying to revive a SW Ep1 for a friend, but I have never owned a pinball 2000 and I am quite lost...
Right now it's not booting.
The computer inside can be heard powering on, several leds in it are red.
Only 5 of the LEDs on the driver board are on (see pic).
Screen is on but there is no pic.
No GI.
Any idea on what to check?
I looked here but did not find anything
https://pinwiki.com/wiki/index.php?title=Pinball_2000_Repair
Many thanks in advance!
#2 2 years ago
Get in touch with Borygard he's done work on them.
#3 2 years ago
The LEDs under the fuses typically indicate bad fuses.
If you pop out those fuses and test them with a multimeter, do they test bad? If so, go ahead and replace them.
#4 2 years ago
At initial power on, LEDs 15-17, LEDs 3, 8-10 are on. After about 15 seconds, the monitor screen will turn from white to black (and the text "TESTING" will appear), and all remaining LEDs (LEDs 4-7, LEDs 11-14) will come on (assuming the coin door is closed), and the Health LED2 will start to blink. Note if LED16 (+12 volts, the GREEN LED) is out, +5 volts LED17 will be missing too. Without LED16, the whole game is pretty much dead.
Assuming the system is not communicating with the playfield - the PC is not booting into the proper sequence
Reset the PRISM card - Check P/S on PC (Replaced)
Section - 4.5 Motherboard Issues - Bad caps?
Validating if the computer is OK:
Remove the PRISIM card and install a VGA monitor - the computer should now boot like a standard PC. Video should be seen on the computer monitor and then "No boot device found" which is OK. If there is nothing then you can troubleshooting the computer P/S/Caps, reset Mem.
#5 2 years ago
Quoted from ForceFlow:
All fuses are tested good.
Quoted from PinNeu:
Thanks, will check that.
Main issue will be to find a VGA monitor
So far it only lits up those leds, nothing else, coin door closed.
#6 2 years ago
found a VGA screen:
have absolutely nothing on screen with or without the Prism card
all caps seem good.
Changed the batteries
power supply is delivering +10 and -10 instead of +12 and -12, every other values are ok.
Replaced the 6.3v 1000 uf caps => no change in behaviour.
Other caps really seem fine, and those pads are freakingly small, changing more is also a risk.
#7 2 years ago
Installed a RFM computer into the SW Ep1: it's all good.
Issue is cleatly with the computer.
Does anyone know of a place with info on how to troubleshoot them?
$ 169.99
Maine Home Recreation
$ 234.99
Cabinet - (Alt) Translites
Cento Creations
$ 14.95
$ 135.00
$ 259.99
$ 49.00
Pixels Arcade Games
4,500 (OBO)
Bay Shore, NY
KAHR.US Circuits
5,195 (OBO)
West Chicago, IL
$ 54.00
Slipstream Mod Shop
$ 69.50
€ 50.00
Pino Pinball Mods Shop
Playfield - Plastics
The Pinball Scientist
4,500 (OBO)
Oakdale, CA
$ 120.00
3,596
Hackensack, NJ
$ 120.00
This page was printed from https://pinside.com/pinball/forum/topic/p2000-sw-ep1-issue and we tried optimising it for printing. Some page elements may have been deliberately hidden.
