(Topic ID: 261678)
OXO Repairs completed thanks to you at Pinside.
By PumRibby
1 year ago
  • 12 posts
  • 6 Pinsiders participating
  • Latest reply 1 year ago by Troostr
  • OXO Williams, 1973
#1 1 year ago
I started repairing pinball last year. This is my second EM. The first, VOLLEY, was 95% working when I got it, so there wasn't much to do. This one, OXO, was the opposite. It was almost completely non-functional. But through this great site and the wealth of knowledge it contains, I have successfully brought it back to life. I'm still struggling with reading schematics, but I'm getting there. So, I would like to offer up my repair notes here in hopes it can help someone else in the future. I also have repair notes for our BSD that I repaired last year with help from this site that I may post as well. Thanks.
Cleaned and adjusted all score reels, steppers, switches
Problem: Reset sequence not resetting all reels to 0.
Repair: Readjusted switches on problem score reels.
Problem: Reset sequence doesn’t shoot the ball from out hole. Essentially getting stuck on step 11 of the Williams reset sequence from the EM repair guide. The score motor keeps running.
Repair: Magic….After checking the entire path from the score motor to the transformer, Somehow hitting the plumb bob tilt to cause the tilt relay to activate then putting a ball in the outhouse fixed this issue. Perhaps a plate on a relay wasn’t aligned properly and that somehow knocked it into position?
Problem: 10 point relay, 100 point relay, 1000 point relay stays energized when hit. Coils stuck on chimes, No. Match Unit, and elsewhere.
Repair: Readjust switches on point relays. They were too close together to pulse properly.
Problem: Overheated coil on "No. Match Unit"
Repair: New Coil
Problem: Gate would stick open.
Repair: Disassembled and cleaned post.
Problem: Multiple relays buzzing.
Repair: readjust switches and springs to allow the relay to pull in effectively.
Problem: Points not displaying on reels. Even with manual activating of point relays no score would show.
Repair: Cleaned switches on TILT relay again. Specifically the two M&B.
Problem: 100 points not showing on any reels.
Repair: Readjusted 100 point relay switch for drum reels closer together.
Problem: Knocker staying energized when the ball rolls over right rollover after special lit.
Repair: Readjusted Right Rollover Relay.
Problem: Rollover Button not activating.
Repair: Traced it down to a wire that had come off of the Rollover Button Relay.
Problem: Sometimes rollovers won’t tally a score or light “x” and “o”
Repair: The long bar on the reset bank was slow to return to home causing relays to stick. The solution was to replace the spring on the reset bar.
Problem: “9-0” not lighting.
Repair: Bad LED bulbs. They may have shorted during a repair of something. I don’t know.
Problem: Flippers buzz in hold position even after rebuild.
Repair: I’ve tried a few things to solve this, adding a spring washer, readjusting coil stop, they still buzz.
Thoroughly cleaning and adjusting the switches on the relay bank fixed a myriad of gremlins.
I took a thousand photos of the repair, but I'll only post a couple. Thanks again. Now on to the next machine!
IMG_0767 (resized).jpegIMG_2398 (resized).jpgIMG_2456 (resized).jpgIMG_2447 (resized).jpg
#2 1 year ago
Congratulations, Finishing an OXO means you've graduated. OXO is a very complex EM.
It has so many relays that it's actually noticeably heavier than other games of this era.
Thanks for coming back and posting all your issues and repairs. It may help someone in the future.
#3 1 year ago
Excellent job pumribby, and a fine looking em also. thanks for posting the troubleshooting steps also.
#4 1 year ago
That monster relay bank makes for one of the most satisfying reset sounds in pinball, I gotta say (a nice heavy ka-thunk). And yes, hairy to work on. Kind of wish I still had mine, but eventually you master the shots and you need to move on. Love the art...
#5 1 year ago
Quoted from edednedy:
I feel a lot more confident now around EMs. Plus, lifting that playfield up and down and in and out gave me a new appreciation of the simpler machines and a great work out.
#6 1 year ago
Quoted from AUfan:
Thanks. I thought it best to pay it forward for all the help I got just by lurking on this site.
#7 1 year ago
Quoted from arkuz:
It does sound cool, if not scary at first.
#8 1 year ago
Great job! That glass looks better than average. We like ours. It is definitely the most complex EM that I have dealt with.
Dave
#9 1 year ago
OXO My first exposure to pinball, and still one of my favorites! Yours is in really nice shape too! Well done! That’s a tough one to get through.
#10 1 year ago
Quoted from dgAmpGuy:
Dave
Thanks. I guess it just gets easier from here. There no way another pinball will be as difficult, right? LOL
#11 1 year ago
Quoted from Troostr:
Thanks, I see you’re in Artesia. I run the Arcade Dungeon in Alamogordo. If ever you come by this way, you can stop by and play.
#12 1 year ago
Quoted from PumRibby:
Absolutely! That would be cool! If you come to Artesia, I show you around my dairy and farm, and a pretty cool collection of about everything.
