Hi jdapolito
the "preowner / hack" is an mystery --- want to try with an jumper-wire (permanent set) - I have taken HowardR 's JPG in post-5 --- see "my blue jumper" --- exercise care - on some or just on one of the many lights You will see "wire of color-brown in the pin" - wire of color-brown comes to one side of one or several light(s). IF (if, if) You happen to use "other side of the lamp(s): You then make an short and the fuse will blow.
IF (if, if) the lights work with the jumper: You may let the jumper in the pin and do some "documentation".
IF (if, if) You are interested in the mystery: You must follow the wires starting at "Switch C on the Ball-Index-Relay" - start at this switch-C - then follow to whereever they go - investigate on the wiring. Greetings Rolf
