I am having an issue with the left outlane switch on my STTNG. The switch registers just fine in the switch edge test manually. With the glass off, I can throw the ball at any speed down the Outlane manually and get it to register. When I put the lass back on and play a game, the all can o down that outlane as many times as it wants and won't register the switch. At first, the switch seemed too tall so that the ball would just skip over it and drain. I adjusted the switch to what appears to be the proper height based on the other rollover switches I saw. Problem solved, right? No. I know the switch is good as I can depress the arm all day long with my finger and it works just fine. It has to be an adjustment somewhere or just something else I haven't accounted for. Thanks!
