(Topic ID: 271580)
Outhole switch replacement for high speed
By Matthew2015
2 years ago
  • 2 posts
  • 2 Pinsiders participating
  • Latest reply 2 years ago by Spybryon
#1 2 years ago
i am replacing a high speed out-hole switch but the part #17-1067 is not made anymore and the #5647-12133-12 is used as a replacement.
but #5647-12133-12 has 3 metal tabs for connections instead of 2. Do i wire it the same as the original is wired with the green wire on bottom and white wire on the lower left connector ?. It would help if you had a picture of this already connected to help me out.
#2 2 years ago
Use a voltmeter on the old switch to determine if it's normally open or normally closed. Probably it's normally open.
Then on the new switch, check for a pair of lugs that act identical to the old switch.
Assuming you want normally open, then when you find that pair, the other lug which you don't want to use, is going to be normally closed
Other
$ 35.99
$ 52.99
Pinball Shark
Shooter rods
$ 54.99
Shooter rods
$ 12.00
Toys/Add-ons
RobTune
Toys/Add-ons
Benton, AR
Other
This page was printed from https://pinside.com/pinball/forum/topic/outhole-switch-replacement-for-high-speed and we tried optimising it for printing. Some page elements may have been deliberately hidden.
