(Topic ID: 202858)
out of sight pin hold relay never comes on
By Boltronix
6 years ago
  • 5 posts
  • 3 Pinsiders participating
  • Latest reply 6 years ago by Boltronix
#1 6 years ago
out of sight pin hold relay never comes on. manually pressing start relay gets the reset process going than control bank relay 'U" chatters as score motor runs. when i hold "U" for a second it fires the control bank relay and score motor stops running. BG has game over and tilt lites on but replay button does nothing.
#2 6 years ago
hold relay measures 34 ohms in circuit
#3 6 years ago
The hold relay would be relay R on the schematic. Check the following switches to see if they are clean and adjusted properly:
Lightbox tilt switch - slate/black wire and yellow/black wire
S relay switch - yellow/black wire and slate wire
R relay switch - yellow/black wire and slate wire
#4 6 years ago
When you say hold do you mean "Hold" (R) or "Tilt Hold (H)?
Only asking cause I"m having a similar issue on my machine but it's H that's not getting power. Same symptoms as well.
#5 6 years ago
Thanks for chymin' in guys sometimes i get lazy and post. clean and adjust the appropriate contacts per the schematics always works.
This page was printed from https://pinside.com/pinball/forum/topic/out-of-sight-pin-hold-relay-never-comes-on and we tried optimising it for printing. Some page elements may have been deliberately hidden.
