When it comes to household electrical work I'm pretty much self-taught, know enough to be dangerous but reasonably cautious, etc. I've rewired rooms and panels and appliances and the like but sometimes the stuff terrifies me. For instance, I don't understand the seemingly arbitrary decisions as to what's "code" and what isn't.
Case in point: I've heard and read arguments, from licensed electricians no less, who say that when installing a new wall outlet or switch, you should always use the little holes whereby you simply strip 3/4" or so of insulation from the wire (use the gauge on the receptacle if in doubt) and stick the conductor into the little holes near the screws. The holes have tabs that are supposed to bite and give a nice secure connection. No screws to accidentally-not-quite-really-have-tightened all the way, or have loosen over time. It's supposed to be quick and easy and permanent and safe.
To that I say BULLSHIT! In at least 4 different structures now, wired and/or retrofitted at various times and locations by different people before me, every time I've encountered a flaky / shorting / dead / unreliable / dangerous / etc switch or outlet, and go to inspect or replace it... its been wired with those stupid quick-connect terminals instead of the screws! And incredibly, sometimes the conductors have backed out of them! This doesn't seem like it should be possible, but yet it is happening somehow. Not once on a fluke / poor-install case, either. The stripped ends look to be proper length, and seem to bite well enough if I push them back in - though not always. Sometimes these outlets look brand-new otherwise, so it's not like I could suspect someone previously reusing them.
But, you know what has NEVER failed from a mechanical-connection standpoint? The screws.
Call me old-school but this is what I will use every. Single. Time. In fact the ONLY reason I can think of for the quick-connect terminals is just that: they are quicker. Sometimes the screws are a PITA. Still, get the right hook on the wire nestled within the recess, cinch that screw all the way down, those things are never coming loose. OTOH, I have dodged a few bullets whereby those quick-connect terminals became downright unsafe over time.
So what is going on? How does "code" allow something so flaky to be manufactured and endorsed? Or am I encountering the work of people who are somehow screwing up something that should be so simple? There has to be something to this. It can't be just me... or is it?
