Quoted from northvibe:Ahh man! Picked it up!
Guy mentioned the 8 track player works, but the tape isn’t original.
Which screw(s) should I undo to get the gun off? It won’t fit in the elevator at work with the gun on.
The best way should be under the stock , Not exactly sure which screws but the ones near the trigger guard ,
If you can get the stock loose , ease the wire through a little as you lift up the gun , just a few inches , careful of the 2 wires that go to the trigger switch , and then just twist the gun sideways , rest it or support it with a blanket or something .
leave the bottom area alone if you can , so it wont all need re adjusting .
2nd idea , If your cabinet has a hinged lid and you can unplug all the wires?
Take the hinge fixings out and remove the complete gun and lid .
My friend has this game , I can check with him if the second idea will work ...
good luck
