(Topic ID: 172194)
Original Medieval Madness
By dzrossi
5 years ago
  • 3 posts
  • 3 Pinsiders participating
  • Latest reply 5 years ago by bobukcat
#1 5 years ago
I was very fortunate to find and purchase an Orginal Medieval Madness. I was able to fix and restore most items. Two items I am struggling with.
Draw bridge. I cannnot seem to find the right placement to allow bridge to close when in the up position. I would like to request someone with an orginal to post some pictures of the underside drawbridge mechanics. Specifically I am looking for the position of the swing arm on the drawbridge when it is in the up and down position.
Inserts One of the inserts the LOCK 2 had a hole in it. I replaced and purchased laminated decals from planetary. I spent 60 dollars and honestly it is horribly translucent as the light shines right threw black. Looking for ideas to make my own. Biggest challenge is how do I get access to a printer that prints white. Folks have posted hobbies stores have it but most in my area have closed up and the ones left do not have a printer that prints white. Looking for what others have found and done.
#2 5 years ago
Quoted from dzrossi:
That looks normal to me. Sometimes a ball can get trapped back there when the bridge is raising. If the bridge were to close all the way the gears would strip out as the bridge pushed against the ball trapped between the bridge and gate.
#3 5 years ago
There is a thread somewhere that shows how to use small zip ties to tighten up the gap when the drawbridge is closed. I did it on mine and it definitely worked but eventually the zip tie broke and I haven't bothered installing it again because it doesn't really bother me, and it does provide some extra room for the ball trap scenario.
