Quoted from punkin:I never thought i'd say this, but my pinball machine is going moldy.
How hard is it to get the perspex playfield off of the plastic base?
That looks like the usual “white fuzzies” this machine is plagued with. Captain Neo talked about it at length in his for sale post.
The vacuum-formed moonscape is not properly suspended and rubs against the plexiglass molded playfield. The moonscape rubbing becomes tiny white dust particles of plastic and clings to the playfield like dust on a static-charged balloon.
To take apart the playfield and clean those is a bitch and a half of work.
You have to first depopulate the playfield, then unscrew all the screws securing it to the top and bottom of the playfield mounts. Then you’ve got to separate the layers that are screwed together and slid into the rails.
It’s awful. The rails are used as a spacer, and the vacuum-formed playfield is so exceedingly delicate it feels as if it will break apart at any moment.
Here I circled all the places where the vacuum-formed plastic was rubbing and creating fuzzies. Most noticeably clear is the arrows. The ones by the flipper are messy and probably indicates the flipper itself may be pressing against the plastic playfield at some point.
Here you can see the playfield has multiple “peaks” that rub against the plexi. All the fuzzies have amassed near the insert light, probably something to do with the heat, I assume. Once you clean these areas (with extreme care) just touch-up the color and replace.
Perhaps CaptainNeo has recommendations on how to match the color and prevent this issue from reappearing.
