I have an odd issue on my TZ. I can trigger the Opto receiver of Switch 75 (Upper Play field Exit) with a flash light. I can point the transmitter of Opto receiver of Switch 75 (Upper Play field Exit) at the receiver of Switch 76 (Lower Play field Exit) and the light triggers the 76 switch. From this I know there are no issues with the Opto transmitter of Switch 75 (Upper Play field Exit).
I can not get the transmitter of Switch 75 (Upper Play field Exit) to trigger the receiver of Switch 75 (Upper Play field Exit). ... even if I hold them face to face. I have replaced the receiver twice.
The receiver for Opto receiver of Switch 75 (Upper Play field Exit) is much less sensitive than the receiver for Opto receiver of Switch 76 (Lower Play field Exit). If get the flashlight anywhere near the Opto receiver of Switch 76 (Lower Play field Exit), it switches. Receiver of Switch 75 (Upper Play field Exit) takes a direct beam from the flash light to trigger. I am determining if the switch switches by using the edge test.
I have reset all the connectors I could find. Any thoughts? Replace the Opto board? I am going to pull the mini play field now and look for a connector or short there.
