(Topic ID: 332554)
Optical spinner?
By pinbuoy
1 year ago
  • 27 posts
  • 17 Pinsiders participating
  • Latest reply 11 months ago by Sonic
#1 1 year ago
Jack Danger talks about the optical spinner on Foo Fighters, I don't think I'm familiar with these. Is there a lil paddle added to the spinner? And that goes thru the slot in those lil black boxy optos?
#2 1 year ago
Elvira uses one as well
I like them as they spin longer with a solid shot
Very satisfying
Spinners with the traditional micro switch only spin so long
#3 1 year ago
There is one on the James Bond I unboxed this weekend. It 100% spins better and longer than any spinner on any machine I've ever had.
#4 1 year ago
Quoted from SantaEatsCheese:
He did say it spins forever.
In the FF stream you can hear it in the background spinning like crazy
#5 1 year ago
I think these were introduced with Beatles?
Basically it has an opto pointed across the width of the spinner, and as the spinner spins, the spinner 'panel' itself blocks the beam. No need for any additional bits on the spinner or a switch to sap energy as it spins
#6 1 year ago
First introduced with Capcom’s Flipper Football in my experience. They’re awesome, less mechanical parts to absorb energy and slow the spinner!
#7 1 year ago
Ahem.
Police Force. Optical spinner. 1985.
#8 1 year ago
Wish Stern would release a parts number for these and parts to Marco, I wanna try and retrofit 3 into Ironman
#9 1 year ago
The way these work is a little different than a traditional opto. If you look the emitter and receiver are side by side, and as the spinner passes in front it’s bouncing the beam back.
That means no need to have parts on either side to break the beam.
Retrofit kits for mechanical switch spinners would be awesome. But I wonder if they wouldn’t need a little logic. I think with how they work it might register a spin with every half rotation?
#10 1 year ago
Quoted from Aurich:
The way these work is a little different than a traditional opto. If you look the emitter and receiver are side by side, and as the spinner passes in front it’s bouncing the beam back. That means no need to have parts on either side to break the beam.
On the opto-spinners like on the Beatles, the emitter and receiver are across from each other, so it is breaking the beam.
Quoted from Aurich:
Well that would make it seem like they spin forever!
#11 1 year ago
Quoted from zacaj:
Great point. Thanks
#12 1 year ago
Quoted from Aurich:
I plan on getting some of these when available and adding them to classic stern games. Would be easy to add an alternator to the software logic to ignore the 1/2 spin.
Firepower would be a good choice to retrofit as well, since the default is to 'delay' counting up the score and it whips it off all at once. Probably add something like that to seawitch, I think it would spin so fast that the older boards might not be fast enough to process everything.
#13 1 year ago
Quoted from slochar:
I'd love to add one to Meteor. With the updated code out there for it, adding logic shouldn't be an issue.
#14 1 year ago
Quoted from misterschu:
Yeah Beatles must have been Sterns first revision I guess with the emitter and receiver on opposite sides and then on Bond they refined them with the emitter and receiver on the same side which looks a lot better, really cleans up the whole look.
E79E1097-D573-4D37-AFB4-1C9443D8025F (resized).jpegE79E1097-D573-4D37-AFB4-1C9443D8025F (resized).jpegE9B3A285-9255-456A-AF24-87BA4335A40E (resized).jpegE9B3A285-9255-456A-AF24-87BA4335A40E (resized).jpeg
#15 1 year ago
Rush has the optical spinner, Tx and Rx on one side.
I love how that thing spins.
#16 1 year ago
Quoted from cookpins:
Yep, adding it to DickHamill 's or mine http://tsqmadness.com/slochar/ZIP/ should be easy enough.
The biggest issue I'll probably run into with the original style coding is getting the spinner counters to work > 200 spins! My mechanical meteor spinner gets in the 80's most of the time.
Meteor is slated to be updated with my new 7 digit style coding which fixes the quirks left over from the Oliver Kaegi verison.... just have to carve out some time for that.
The optical with the RxTx on one side is the way to go I think for a retrofit. Will have to come up with other stickers for it though.
Can you imagine nine ball with an optical spinner??? That would be really crazy.
#17 1 year ago
If I can get a few, hopefully Marco get them listed soon (odd for them not to have a part listed early and these have been out for a while now) I will put them in Ironman and see how it goes.
As soon as I played Beatles back when it released I instantly said these would be cool in Ironman, set Monger to hard or very hard and rip those spinners!!
#18 1 year ago
Right, I should have been more clear that that style does exist (and isn't a Stern invention) but all the new ones are doing one side. I don't know if that is something Stern innovated or not either, but it is a much cleaner way to do it.
Thanks for posting those pics J85M that's helpful.
#19 1 year ago
Wouldn't you need some type of logic board to covert the signal or code changes to retrofit existing standard micro switch spinner games? Due to optos being normally closed vs normally open? Maybe I'm getting that backwards, but either way, traditionally optos register differently than micro switches I thought. Perhaps that is an option I'm unaware of depending on how you wire it.
Though perhaps the type with both tx and rx on one side would operate more like a normal switch, if indeed you're not breaking the beam, but instead reflecting it back to trigger the switch. That would seem more like a normally open switch behavior if I understand it correctly. Other than the potential two hits per spin I guess...
#20 1 year ago
Quoted from Aurich:
I would suspect there is a small driver board for these just like any other opto that translates the Opto state to the switch matrix, drives the proper voltage to the xmitter, etc.
#21 1 year ago
Quoted from Aurich:
Ya, the single side tx/rx is much sleeker
#22 1 year ago
Quoted from PinKopf:
This is an interesting point regarding the double counting per spin; if it's reflecting back you could just put some matte black paint on one half of the spinner to prevent reflection.
#23 1 year ago
Iron Maiden was also made in 2018 - does it have optical spinners as well?
#24 1 year ago
Yeah the real issue is an opto spinner detects two switch closures compared to one on a mechanical spinner. You'd have to have some sort of logic block to get the game to see the correct number of spins.
Quoted from John-Floyd:
No. I think it uses skinny spinners though (which are more common these days anyhow). Less mass than a traditional spinner = less loss in angular momentum therefore more spinz
#25 1 year ago
Thankyou - I Appreciate the answer.
#26 1 year ago
Quoted from PinRetail:
Ahem.
“Spinner” being generous! Yes, it fits the definition, but you only use it on the skillshot plunge as a toy that only gives a few spins!
When’s the first use of an optical spinner as an actual spinner shot and not just a plunge?
4 months later
#27 11 months ago
https://pinside.com/pinball/forum/topic/mampm-creations-mrs-catalog/page/3#post-7682526
Hot off the press...it ain't mechanical, it ain't optical....but yes, it is an MRS spinner!!!
Matt & Dan
5,750
Brunswick, GA
$ 139.95
Hookedonpinball.com
$ 50.00
Duke Pinball
6,999
Wood Dale, IL
$ 175.00
Raiden Mods
$ 69.99
Inscribed Solutions
$ 6,999.00
Maine Home Recreation
$ 427.00
PinWoofer
$ 26.00
Pin Monk
Trade
Machine - For Trade
Westbrook, ME
Diddy's Pinball Mods
$ 185.00
Sparky Pinball
Rubber/Silicone
NO GOUGE PINBALL™
Raiden Mods
$ 26.00
BomberMods
Slipstream Mod Shop
BomberMods
$ 1,700.00
Raiden Mods
$ 26.00
Pin Monk
6,000 (OBO)
Bryan, TX
$ 19.99
FlipMods
$ 16.50
$ 29.95
Paradise Distribution
