(Topic ID: 22805)
Opinions of Possible New Phoenix Play Field Layout
By Bowman9
11 years ago
  • 15 posts
  • 4 Pinsiders participating
  • Latest reply 11 years ago by aeandreas
#1 11 years ago
Hello All,
I am looking for feed back from owners and or players of Williams Phoenix (1978)
http://www.ipdb.org/showpic.pl?id=1780&picno=5872
I am contemplating rethemeing my Phoenix, but instead of just adding new graphics I was thinking of changing/updating the layout some.
I would not be changing any of the code (that is beyond me), so the original rules would remain in place.
The game is pretty basic there are five rollovers at the top (actually four, 1 and 5 are the same), complete the five rollovers to spell P-h-o-e-n-i-x and advance the value of the lefthand bullseye target. There are two sets of 4 drop targets (left and right) when either are completed they will advance the bonus multiplier. There is a spinner on the right side that increases in value when lite and two single drop targets in the center that reset when the 2 and 4 rollovers or the inlanes are triggered.
Like I said a pretty basic game no real bells and whistles.
Here are the changes I would like to make in hopes of making the game a little more interesting - (hopefully the before and after images attached correctly).
The five rollovers at the top would now be four stand up targets placed throughout the play field. The three rollovers that would take their place would just be low point value switches.
The bullseye target would become a ramp (ramp shown from Party Zone), I have not decided on where/how the ball would re-enter back on to the playfield, maybe you have an idea.
The two sets of four drop targets would just be moved slightly.As well as the single drop targets and pop-bumpers.
I would like to add a "spinning post disc" like in TOTAN to the (off) center of the play field to make the ramp shot and the 1-4 stand up shots harder. I am not sure what points value I would give the "spinning post disc" it may just be a low value switch (if it gets hit alot) or replace the old spinner.
This is project is still in the pre-pre-planning stages so there is no deadline.
Let me know what you think.
Bowman 9
Old Layout Left - New Layout Right
#2 11 years ago
I like this idea, but I definitely know that some will be against this idea.
#3 11 years ago
Yeah, it's kinda hard to judge what others will say.
Re-themes can be a touchy subject, but I am still looking for input on the new layout.
#4 11 years ago
It looks like you are taking a lot of stuff away. Will that make it hard to complete certain items? Looks pretty neat though.
#5 11 years ago
Nothing is being removed.
I just have not decided where the inserts (lights) will go yet, it makes the play field look sparse in comparison.
3 weeks later
#6 11 years ago
Because I would like to add the spinning post disc and all new artwork I am having trouble finding room for all the inserts/lights on the playfield, do you think would be ok or bad to remove duplicate inserts?
By duplicate I mean the letters in the word Phoenix, P and H are both worth 10K, O and E are both worth 20K, N and I are both worth 30K, the X is worth 40K. So by this logic I could get rid of 3 inserts to allow for more room above and below the playfield.
Any thoughts?
2 months later
#7 11 years ago
I am interested in where you placed the lights. Are you done with your work?
I am thinking about redoing my Phoenix playfield but I think I am going with the original layout. Would you mind sending me the layout information on the original playfield?
Thank you
Al
#8 11 years ago
I still have not finished the insert layout yet.
I have some rough mock-up artwork I would like to use, but it fights for the space where I would like to place the new inserts. So when I try and move the inserts they fight for space with the mounting brackets underneath the play field.
It seems to be an endless cycle.
Sure I can send you a copy of the original play field layout.
Just to be clear there is no artwork, it is just a layout of the holes in the play field like the image in my first posted above.
What format would you like the file in?
Oh, I would strongly recommend test printing the file first to confirm that everything lines up correctly with your Phoenix play field before adding your new artwork, just in case there are any differences or errors.
#9 11 years ago
An adobe cs5 or something that can be imported to CS5 would be great. If I could also get whatever the raw format is (autodesk or whatever you use) might be helpful as well.
I am interested in scanning in the artwork and laying it on top your drill pattern. So if the dimentions are real good I can line up the artwork on your layer possibly. Also I am thinking if I have yours printed with the addition of cenetring points I can use that for the "drill and trim" that I do by hand.
My playfield is well worn and I would like to freshen up the machine in this way.
How are you going to get the new artwork onto your playfield?
#10 11 years ago
OOPS,
I almost forgot.
Thank you very much.
Al
#11 11 years ago
Quoted from aeandreas:
I have not figured that part out yet, I might do a vinyl wrap/overlay or see what John Greatwich would charge for a direct print - http://greatpinball.com/services.html
But most likely it will end up being an overlay of some kind.
Bowman
#12 11 years ago
If you are interested I uploaded a picture overlaid on your print.
#13 11 years ago
Is this with your new artwork or still using the old as reference?
How did things lineup, remember I would strongly recommend test printing the file first to confirm that everything lines up correctly with your Phoenix play field before adding your new artwork, just in case there are any differences or errors.
#14 11 years ago
This is with the original artwork.
#15 11 years ago
There were some registration problems. I thought I could print it out on something cheap then adjust the alignment.
I am just playing around right now. It really needs to be cleaned up.
$ 12.50
RoyGBev Pinball
$ 170.00
Displays
Digipinball Shop
$ 18.95
$ 9.95
$ 11.00
Tools
Pincoder Store
This page was printed from https://pinside.com/pinball/forum/topic/opinions-of-phoenix-play-field-layout and we tried optimising it for printing. Some page elements may have been deliberately hidden.
