I am in need of opinions, to help with a decision that needs to be made.
Likely, most of us are familiar with LED strips added to your games.
With matrix, we have added, 10, 20, and 50 SMD in 6.3V.
Much of these are used on ones Apron, and the longer, on the back splash.
I have created a new version, that I am in need of opinions, as I really dont want to stock everything times 3.
The first version is a new Frosted strips.
like a Frosted SMD bulb, we have created the flexible waterproof coating in Frosted!
What this does is soften and diffuse the light, dropping the brightness a bit, around 20%.
Its easier on the eye, if one happens to look into them on an apron.
It also cuts down, but does not eliminate, glare completely, when used in a Back splash, say like a Shadow.
So what are your thoughts on frosted? Should I change all products over, or just add white and purple...the ones used more in this application?
Has anyone had spotting when used in GI plastic area or MOD?
My second question is background color.
While our new Micro strips should be black, what about the remainder of the strips?
Should I make just frosted whites and purple in Black, or should all be changed to black?
How does black look on ones apron compared to white, in your mind.
Your input is greatly appreciated.
Art
