Looking to make a cheap spray booth for clear coating fields. I may only use it a few times.
Looking if the OTS is worth it https://www.homedepot.com/p/HomeRight-Spray-Shelter-8-5-ft-x-6-ft-White-Polyester-C900038-M/206260426
I am thinking I need to position the play field lower (maybe even spray on my knees) to the ground on that one as its 5.5' high and probably tapers. I also need to use a tarp to make a proper door as the one with it is made of mesh.
or should I go more traditional route and make one from PVC pipe and tarp?
