I thought about doing this back when I was putting the skill shot in, but I think it's "too much skill shot" if that makes sense. I've definitely gone "too far" in the past with game mods (Night Rider is CLOSE to being too far, but it's still the essence of the game.... Trident was definitely too far/too many changes. I'm aiming for the spirit of the original game with small tweaks.)
Quoted from Spudgunman:
Latest, 33 I think (just burned last night will be next to game this weekend)
I can video the 6mil happens every game I make the skill shot - I am not aware of any switch malfunctions - Original code played perfect. I can snap a photo of my DIPs switches turned on 17-19
As for ball walk - I can video as well - might need more of a check for lost balls, not sure what to say but the game was lost in code due to lost ball on walker.
You definitely shouldn't be getting 6 millions for a skill shot - which set of roms are you using, the 716, the 732, or the 512 on a weebly board?
The skill shot is supposed to spot a letter if you need one, spot a 5-4-3-2-1 drop if not, and score 25k if neither makes sense. (i.e. you have all the drops already, and blast off is already spelled)
At bootup, all the displays should show all zeroes and the ball walker should step 3 times - then the maze switches will clear the balls out on their own. You're supposed to wait for the balls to hit the drain - stock code waits for balls to hit the trough switches, but it only runs 7 times - if the balls aren't there after 7 cycles, it lets you start a game there as well. There is rudimentary ball search code built into the stock game - if a ball hits the walker entry or the maze switches, they will clear.
What happens if you miss the skill shot does it play normally?
Do other things work properly? i.e. bonus ladder 19k, quickshot off B/O to right spinner and blast standup, etc.?
I plan on popping an mpu200 in there later today to see what happens with that because all my development takes place in the 512 socket on the weebly board - there "shouldn't" be any difference between the boards, but I will double check it to make sure. (I'm not using the extra capabilities of the weebly board in this instance)
