Any suggestions to help me fix my latest problems,
It all started yesterday while playing the Shadow with no errors.
1ST, the drop down wall target didn't return up (or down I cant remeber), upon investigation the wall target has snapped at the very bottom causing it to wedge in its either up or down position, I may try and fix or get a new one.
While I saw this I noticed diode across switch on this assembly was loose and i soldered it in place.
2ND, upon power up I now get 3 nasty messages,
GND SHORT ROW 1
CHECK SWITCH 51 WALL TARGET DOWN
ER. WALL TGT. BAD CHK SWITCH/COIL
3RD, so now I have no switches in row 1 operational.
In test solonoid mode the wall target will go up and down no problems, also I can't test the switch as it is row 1. I assume the coils on assembly are fine as they are working in tests.
Is it possible a broken diode can take out a whole row?
Any hints or clues to speed up my fault finding.
