That board has had a rough history at some point. The resistor below Q74 was burned at some point and looks to be replaced. I'm also suspicious of the resistor network above Q76... seems a little scorched at the end. And the exposed trace right above Q76 looks like it was patched with a piece of wire between Q76 and 78....
...and speaking of Q76, it's been replaced once before. Look at the shape of its "grounding tab" and compare to the others.
Given all that scorching damage, I would be very careful working on this board. It may be quite fragile.
But I would remove it anyway, to inspect it very carefully for other tell-tale hints and signs of past repairs and possible trouble spots. It's always a good idea to find what you can, to trace back to the playfield and make sure the source of the problem is actually fixed.
