(Topic ID: 218470)
Only first ball given - Williams Big Chief.
By Lambecka
5 years ago
  • 5 posts
  • 4 Pinsiders participating
  • Latest reply 5 years ago by Lambecka
#1 5 years ago
My old. Big chief from Williams following problem.
Starting the machine , resets and shoots ball to the shooting alley.
Playing first ball and all options on playfield are working. When loosing the ball machine stops and second ball not given.
You can restart machine and and same happens again
Can some one show mee detail of scheme showing line to follow as soos as loosing the ball?
#2 5 years ago
I would check these two switches.
#3 5 years ago
Also check ball index SW. below the righthand red circle in above post and the Extra ball SW between the two red circles. Both SW's are located on their respective relays.
The Ball index RE is there to make sure a player scores at least 1 point for that ball. if the ball drains with out any score the same ball is played again.
#4 5 years ago
Quoted from Lambecka:
... Can some one show mee detail of scheme showing line to follow as soos as loosing the ball?
The first thing that should happen is that the Outhole switch should activate the Outhole relay. That's between 13 & 14 on the schematic.
#5 5 years ago
Quoted from HowardR:
Howard, yes right founded in that area the motor switch INDEX C causing the problem,just a bit cleaning and the outhole switch activated the outhole relais,
This page was printed from https://pinside.com/pinball/forum/topic/only-first-ball-given and we tried optimising it for printing. Some page elements may have been deliberately hidden.
