I found one wire in my williams ski club that is burned to a crisp. It goes to the first rollover light socket in the sequence. It is in the middle of the under pf wire bundle. I started to open it up to see if I can find the color code but only got in 5" or so ( dont have schematics yet). None of the other wires around it seem affected. As I'm cleaning I also see the rollover advance unit stepper has crispy wires as well which makes sense.
But I didn't find any burnt wires on the bottom panel or jones plugs
So the question is what would cause this, over fused and a short combination in that circuit.
And do I need to run all new wire and tie it to outside of wire bundle and then run new wire around the stepper disk? I assume I shouldnt try to leave it as is
Also this is my first mid 60's williams. Is there a trick to removing the stepper disks? They dont pop off like the 70s models. I thought it was the set screw on back cog but still wont budge.
