Quoted from TheLaw:Yes that is a major issue or common problem. Optimus not registering hits is another.
If anyone's having probs with Optimus registering hits, here's an easy fix: His foot lifts off a switch, that's what registers the hits...that switch is on a metal bracket, attached under the playfield. Just take that off, and put some washers inbetween the bracket and pf when you screw it back in. This will make it so that the switch isn't as depressed, and a lighter hit will give you the hit. If it's still not to you liking, try doubling up the washers. Another good mod for Prime is to put an adhesive rubber nub piece (the type you put on electronics so they don't slide around) on his OTHER foot. This foot gets hit by a coil which pushes him back when a hit is registered - so it looks like he got bashed...unfortunately the coil doesn't make enough contact to push him much...however with a rubber nub there, he gets a bit more push from the coil, making the visual effect better.
Quoted from TheFamilyArcade:
I let TFLE in the house, whether or not she stays will be a matter of how much fun we have together in the next couple of months.
Yeah, I had over 1000 plays on mine before I gave up on it, so I totally understand the 'new game excitement'...over the course of all those plays I was putting up with the flaws...but my "deal breaker" gripe was the roadblock code. That was my final straw...however, word is that will be addressed in the upcoming update so - that's a good thing.
