Working on a Olympic Hockey and I have an issue were player 1 doesn't always return the puck to center ice. Mostly happens when goal is made and then you hit the switch that will bring it back to center. Sometimes also happens on a drain. It is not consistent doesn't always stop in the same wrong spot. Sometimes does reset and goes to center ice.
Player 2 works perfect.
I know that the advance unit is going both left and right one way for one payer the other way for the other player then reverse to reset. I think the advance unit should have a Zero position (center) and I'm surprised when this happens it doesn't keep firing the coils to get to Zero.
Help a little stumped on this one.
