machine is a "royal guard"... doing a flipper rebuild... at some point in its lifetime, someone had put one of the "newer" lever arm assemblies on it, so i ordered the complete kit from steve to put everything back the way it should be...
1) on one of the new arms, the bakelite flipper link fit VERY tightly over the stud (on the other arm, the link rotates easily)... this was causing it to bind and not return... breaking my own rule about "assuming", i simply enlarged the hole in the bakelite, and this made the binding go away. question: i'm assuming i did the correct thing here. was my assumption correct?
2) on both of the new arms, there is no room to put the bakelite washer on the stud... is there a "smaller" one, or should i be using something else? see picture below, the left flipper (not rebuilt yet) has the bakelite washer and the right one (the one that is "done") does not...
tia...
chris
