Hello- new to Pinside- researched this but didn't find anything specific - hope you can help
Machine recently was moved- had been operating pretty well for quite a while- now two major issues- playfield lights- although believe a fuse holder (replacement - not Bally original) has worked its way loose and in turn affected the connection.
Of more concern- lane lights and upper 2 bumpers switch between 10-100 points has stopped - checked match unit in back unit- seems to be operating properly- alternator relay not advancing/operating with each point played- did very gentle cleaning of alternator switches- no change. Coil appears to be 70+ ohms.
Thoughts to try?
thanks
