Quoted from wlf_:Lazy seller there, and actually you are a good example of how that laziness can lead to unnecessary disappointment :/
Indeed! At least I'm a good example of something!
Has anyone else had an issue with their machine crashing during gameplay and resetting?
I’ve had the game for only 5 days and this has already happened to me 3 times.
Just now I finally made it to the flipper meister mode, got my score up to 10.5 million, and then the game just dies and restarts.
Come on American Pinball, totally disappointed by this.
Is this happening to anyone else?
My machine got delivered to me with 19.6.5 and I updated it the other day to 19.7.27. It has crashed while the machine was loaded with each code version.
Thanks,
Ross
Quoted from rcb5588:Come on American Pinball, totally disappointed by this.
Please contact them. https://www.american-pinball.com/support/service/ or PM ROSH or BarryJ here.
Let them help you. You'll be glad you did.
Quoted from rcb5588:Has anyone else had an issue with their machine crashing during gameplay and resetting?
Thanks,
Ross
Highly unusual - I am curious if you have a bad fan in the computer. Those sound like symptoms of heat buildup
Quoted from Rdoyle1978:Highly unusual - I am curious if you have a bad fan in the computer. Those sound like symptoms of heat buildup
So I actually just went back to the game and manually put it into the flipper meistro mode again. Once the 2nd to last ball drained (thus ending the multiball mode and being left with 1 ball), the screen went black and the game reset. This is how it happened the first time also. It’s got to be something with this mode.
Anyone willing to put their game into this mode who has the updated code to see if their game crashes once the mode is ending?
I think my fan is running fine, as I can always hear it running.
Thanks,
Ross
Quoted from rcb5588:So I actually just went back to the game and manually put it into the flipper meistro mode again. Once the 2nd to last ball drained (thus ending the multiball mode and being left with 1 ball), the screen went black and the game reset. This is how it happened the first time also. It’s got to be something with this mode.
Thanks,
Ross
Send me the logs, that may tell us what is going on, [email protected]
Use a usb stick with no game code on it , just insert in usb extension cable inside coin door with game on, send me what gets put on it
Thanks,
Ross
just happened 10 minutes ago on houdini seance multiball then jackpot both flippers up shaker motor rumble then freeze then dead....... reset
Quoted from rosh:Send me the logs, that may tell us what is going on, [email protected]
Thanks Josh, I just sent you an email with the logs.
Quoted from gmanrulz46:just happened 10 minutes ago on houdini seance multiball then jackpot both flippers up shaker motor rumble then freeze then dead....... reset
Hmm interesting, I don’t really know much about Houdini, but interesting that happened to you. Thanks for the response.
I may have fixed this a week or two ago, but Josh and I will examine the logs you sent and make sure it is indeed fixed. Apologies for the trouble.
Quoted from Ferret:I may have fixed this a week or two ago, but Josh and I will examine the logs you sent and make sure it is indeed fixed. Apologies for the trouble.
Awesome, thanks!
I made this topper for Oktoberfest. The idea came from another member. I had to heavily modify them to fit with low ceilings. They can be hard to find in pairs but best place to check is ebay. If this doesnt make you want to have a beer and play then nothing will.
Quoted from Viggin900:I made this topper for Oktoberfest.
That's awesome!! How did you manage to get the bubbles in the beer!!!??? I want it!!!
New Oktoberfest owner here. Did anyone have any issues with the door under Otto's bar when they first turned their game on? If his door is open, the stepper motor sounds like it is trying as hard as it can to close, but nothing is moving. The door works fine in test mode and seems to not be hung up on anything. It only happens when you turn the game on and the door is open or partially open. If you turn the game on and the door is closed, there is no issue. Obviously the door isn't going to be closed every time the game is turned off. I'm afraid one of my kids is going to turn all of the games on and the motor will burn out! It's really loud too.
Quoted from pinballslave:That's awesome!! How did you manage to get the bubbles in the beer!!!??? I want it!!!
The old scaefer beer signs have them. Works on a bulb heating a tube of fluid and a mirror behind it. Thanks!
Quoted from adborto:New Oktoberfest owner here. Did anyone have any issues with the door under Otto's bar when they first turned their game on? If his door is open, the stepper motor sounds like it is trying as hard as it can to close, but nothing is moving. The door works fine in test mode and seems to not be hung up on anything. It only happens when you turn the game on and the door is open or partially open. If you turn the game on and the door is closed, there is no issue. Obviously the door isn't going to be closed every time the game is turned off. I'm afraid one of my kids is going to turn all of the games on and the motor will burn out! It's really loud too.
I've had one or two reports of this from Barry, and have asked production to alert me if any game coming off the line has this behavior so I can then take a closer look and be able to test a fix. My understanding is that it is fine once you start a game. I don't think there is a risk of the motor burning out.
I assume you are the latest code.
Welcome to the tent!
I havent had that problem but the door does make electric sound when nothing else is going on. Not too loud though,same as grave marker on metallica.
Quoted from Viggin900:The old scaefer beer signs have them. Works on a bulb heating a tube of fluid and a mirror behind it.
Where's the best place to get them? You mentioned eBay... I guess I search on bubbling Stein lamp...
Thank you for an honest answer Rosh. Yes it is the latest code. I reinstalled the code and nothing changed. I also opened a service ticket. Looking forward to hearing back and getting this fixed. Here is a video of what is happening. I turned my Batman 66 on to see the difference in sound. Around the 2:10 mark the noise starts when the game boots.
Quoted from adborto:Thank you for an honest answer Rosh. Yes it is the latest code. I reinstalled the code and nothing changed. I also opened a service ticket. Looking forward to hearing back and getting this fixed. Here is a video of what is happening. I turned my Batman 66 on to see the difference in sound. Around the 2:10 mark the noise starts when the game boots.
When you get a chance, go into settings and in Features turn Otto 'Off'. Then re-boot and let me know if you still get that loud buzz. Just want to confirm it is the door and not Otto creating that sound
I have a fix for it, but no way to confirm until they find a machine with the behavior or we do a beta code release.
Hey everyone,
today I started my Oktoberfest with Otto. I really love this game after just a few hours of playing. So many tent modes with different challenges, cool shots and funny callouts. Especially for a German it´s even more funny.
I got no issues so far, what really makes it a perfect first day.
For me it seems like a keeper for a long time.
Quoted from O-from-DO:Especially for a German it´s even more funny.
Please tell me more!
I would love to know the lyrics in the song at the end of the game. To me it sounds like "I knows it, I knows it".
Quoted from JohnnyPinball007:To me it sounds like "I knows it, I knows it".
Isn't more like I prose it I prose it ?
Quoted from JohnnyPinball007:I would love to know the lyrics in the song at the end of the game.
https://www.oktoberfesttours.travel/oktoberfest-munich/music/ein-prosit/
Quoted from JohnnyPinball007:I would love to know the lyrics in the song at the end of the game. To me it sounds like "I knows it, I knows it".
Sorry for being late with my answer, but LTG already sent a perfect link including the translation. Thanks bro! "Prost" or "Prosit" just means "Cheers".
Funny translations and strange things for a German are...
..."FÜD". It simply doesn´t exist in Germany. Not as a word or any meaning.
..."Schnitzel on a stick" (like found on a plastic near the bumpers). Never ever seen it in Munich or anywhere in Germany. But it´s a nice idea to offer it in 2019
..."Stein", which means stone in German. The original "stein" on the Oktoberfest is called "Mass" (or Maßkrug). It´s a huge glass with 1 liter of beer: https://www.oktoberfest.bayern/wiesn/oktoberfest-2018-was-kostet-mass-bierpreise-aller-festzelte-im-ueberblick-9947993.html There you can see the prices for a Mass in the real tents (tent = Zelt).
Quoted from O-from-DO:Sorry for being late with my answer, but LTG already sent a perfect link including the translation. Thanks bro! "Prost" or "Prosit" just means "Cheers".
Thanks for all the info!
This is a quite thread for it being Oktoberfest! I just installed pinstadiums to cut down backglass glare and brighten the playfield. I play in a dark arcade so for some in bright rooms it may not matter. I think this is a way to reveal the world under glass. So much more pops like sparkles on the bumper cars and the inserts that say whats going on. Most of all the bad glare on the bar door I had to lean down to see whats going on since I don't like using the lcd. Definitly more festive!
20190925_234913 (resized).jpg20190925_235029 (resized).jpgHere is a sneak peak at the new and improved animation debuted at Expo last week end starts at 17:31ish
They really did an amazing job looks like a whole new game!
Code will be released soon!
HEY!
Update animations, new music, voice calls, match sequence, and a ton more!
See release notes for installation instructions and to see what has changed.
https://www.american-pinball.com/support/updates/
Quoted from rockrand:I looked at my ramp and I saw the ball hitting the area I have circled and I bent it out a bit,I had the same trouble and this helped a lot,.
You are the fixer dude! Did the bending of the upper right ball guide yo help left loop shots make it round... as you recommended... it's improved things for sure.
Quoted from Aniraf:Does anyone know how to test/fix a “bar hit” switch? I can’t even find the switch :/.
Page 14 in the manual, you can download the manual from american-pinball.com it's switch #23 in front of Otto in the upper left area.
Sorry, I don't have a game to check to see what kind of switch or what to look for.
Quoted from LTG:Page 14 in the manual, you can download the manual from american-pinball.com
You can download it here : http://s4.american-pinball.com/img/support/2019-7/Oktoberfest-Manual-new.pdf
On the website : american-pinball.com go to Support - Resources - Oktoberfest
Quoted from LTG:You can download it here : http://s4.american-pinball.com/img/support/2019-7/Oktoberfest-Manual-new.pdf
Ty for the response! I should have been more clear as usual . I checked the manual, and I see the switch, but since there is no physical switch I can’t find it on the underside of the playfield. I assume it is some sort of Eddie sensor, but the underside of the playfield doesn’t really have anything there :/.
6A723563-15B3-468B-A6A9-6D9751CA0891 (resized).jpegQuoted from Aniraf:I can’t find it
Email [email protected] and or ask on their website - https://www.american-pinball.com/support/service/
I always assumed that switch is simply the metal plate in front of the bar and the metal plate on the bar itself (so the pinball completes the connection). Haven't tested that theory though
any new streams showing the improvements? From what I've seen, the animations look MUCH better.
EDIT:
found one....
Paul_from_Gilroy is correct, bar hit switch is when the ball is on the metal plate and touches the metal of the bar door. Make sure the plate is firmly pressed level onto the playfield so the ball doesn’t hop.
Quoted from Ferret:bar hit switch is when the ball is on the metal plate and touches the metal of the bar door. Make sure the plate is firmly pressed level onto the playfield so the ball doesn’t hop.
I'd check the ball, and both metal plates to be sure they are clean and can conduct electricity. Mylar or a lot of wax could interfere.
That's quite a switch mechanism... I guess the tiniest of ball launch at the moment it hits the bar door contact will fail to register... I was wondering why mine wasn't registering very often... must check that the metal in the playfield is flush with the pf surface! If the bar metal was angled down a bit it might help push the ball down onto the pf contact before it bounces off the bar door contact
Is it possible that the new code is fleshing out this issue? Now that you describe it, I'll tell you I have been using a playfield protector since day one and I've never seen the API cockpit recommend that there is a switch issue. The way the protector is cut, the ball could have never literally made contact with the metal plate in the playfield because the protector covers it. I had always just assumed that it was some kind of eddie sensor and that the plate was basically an antenna for it.
I am now wondering if my game has never fully worked due to the playfield protector I installed. That said, the switch warning is new. I can confirm that because I have a picture from the first time I serviced the machine in June.
UNADJUSTEDNONRAW_thumb_309a (resized).jpgQuoted from Aniraf:I am now wondering if my game has never fully worked due to the playfield protector I installed.
It can't work if the ball doesn't complete a circuit between the two pieces of metal.
This page was printed from https://pinside.com/pinball/forum/topic/oktoberfest-owners-10-/page/5 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
