(Topic ID: 214342)
Oil-impregnated bearings
By yellowghost
6 years ago
    #1 6 years ago
    Is there a way to re-impregnate bronze bushings. The game I bought had four bushings riding on shafts. The entire mechanisms was covered in grease. Dissasembled and degreased and cleaned everything. Discovered later that these bronze bushings were not to be greased and that would destroy them. Is there a way to re-oil them? I am putting a huge order together and they have two only in stock.
    #2 6 years ago
    Not sure what ones you need, but you can check BDI in Canada. I buy from BDI and Motion Industries. If you go on Isostatic website, they list all their distributors, including some in Canada like The BDI branches.
    #3 6 years ago
    Quoted from yellowghost:
    Apparently they are vacuum impregnated to begin with. So you'd have to do that.
    #4 6 years ago
    Quoted from WillSmuz8999:
    Thanks. I will look into it. I found them.on ebay and they are over double what that Marco guy sells them for. Its a "F19" size bearing.
    #5 6 years ago
    For small quantities, you can check Fastenal too!
    https://www.fastenal.com/products/flanged-sleeve-bearings?term=Bronze+bearing&r=%20~%7Ccategoryl1:"603582%20Power%20Transmission%209and%20Motors"%7C~%20~%7Ccategoryl2:"610631%20Unmounted%20Bearings"%7C~%20~%7Ccategoryl3:"612463%20Flanged%20Sleeve%20Bearings"%7C~
    This page was printed from https://pinside.com/pinball/forum/topic/oil-impregnated-bearings and we tried optimising it for printing. Some page elements may have been deliberately hidden.
