Ok so i just put a little post on the BH owner thread as i discovered something very interesting.
Which as you will see are Easter Eggs! HUGE ones. SO Happy Easter Egg hunting to all.
I was examining the balls for scratches nicks etc and wiping off doing so repetitively until well on the sixth time the ball drained it went into slam mode. Now this should not have happened as i have the old permanent fix to disable this as a solder blob on the the CPU board. So even though the slam switches are disabled you can still invoke it. May work on other Gottlieb machines i have yet to try. But i started to think well that is in the code no scoring at all six drains (SLAM mode) wow pretty cool, now that was really thinking ahead.
So i dug into the code a bit more and WOW it is crazy and very similar to the BOP Easter Egg and you have to sing the exact same song.
Here is a video i made of the gameplay just after doing so.
After doing this routine the sound call outs are just amazing! Enjoy!!
Does it work for you? On other Gottlieb titles? On the aftermarket boards? What is up with all these Williams now Gottleb easter eggs?? I told you the rabbit hole goes deep!
