Quoted from Chosen_S:Dang you, I can't put that in my LE!
You can put these in if you want (esp. the GI and backpanel/apron lights), but the LE is pretty perfect as it is. At one point I had Eli's kit and addressable LEDs installed on the ramps at the same time. However, the LEDs make Eli's kit barely noticeable (especially during with daylight), so I ended up taking off the light tubes. Here is a video showing an earlier install (very early pinduino code, too, so the diversity of effects are minimal) with the LEDs on the bottom of the ramps (as opposed to on the sides as they are now.)
