(Topic ID: 54093)
Official TRON lovefest thread
By centerflank
10 years ago
  • 11,456 posts
  • 600 Pinsiders participating
  • Latest reply 8 days ago by Saltimbanco
  • Topic is favorited by 180 Pinsiders
Topic poll
“Is TRON super awesome or are you a hater?”
  • TRON is unreal, centerflank is supersmart. 460 votes
    73%
  • TRON blows, voters for this option have a small dingy :( 106 votes
    17%
  • Never played TRON, but if Centerflank likes it, it must be fun!!!! 65 votes
    10%
(631 votes)
There are 11,456 posts in this topic. You are on page 228 of 230.
#11351 3 months ago
Quoted from ray3127:
My right sling sends the ball (literally) flying at times, over the left sling & guides and into the left outlane. It will hit the side of the cabinet, which has mirror blades, and has left a couple dings in my brand new blades.
Has anybody else experienced this?
I am considering a less powerful coil. Any other ideas?
Adjust the switch to be a little less sensitive to start.
My slings gobble balls at times, i have considered lower power coils, but less sensitive switches has made a bit of difference. It still does it, but fairly infrequently.
#11352 3 months ago
Are any of the posts showing damage? Launching like that would seem to indicate that the ball is getting hit low...so, anything that would cause lift or that would lower the contact point will be your culprit.
#11353 3 months ago
Quoted from guitarded:
Not that I'm aware of, but I will take a closer look. Thanks for this.
#11354 3 months ago
I'd also check the fasteners on the mech and the linkage if there are no idications of a problem on the topside.
No problem. Best of luck. Hopefully it is something real simple.
#11355 3 months ago
Past club member here, and I ran across a TRON Arcade cabinet mod I forgot I had. It's the original version, which is why I still have it, as I sold the game with the V2 I replaced it with.
Maybe someone on a budget would want it? Or perhaps it would be perfect for a route game? The arcade screen, the coolest part, works the same as the more authentic cabinet version.
Y'all know what the new one costs -- shoot me an offer (pending pics etc) if you are interested!
#11356 3 months ago
Quoted from ray3127:I am considering a less powerful coil. Any other ideas?
That’s probably not caused by too much power but some problem in the mechanics. Slings should not give airbags at all. Have a look at the mechanics and compare left and right. Something might be bent or not correct in some other way.
#11357 3 months ago
in case someone is looking for a TRON LE. My absolute mint LE is up for trade.
I am only looking to replace for Stranger Things LE. Ad in the marketplace.
#11358 3 months ago
!! PRODUCT ALERT !!
Pinball Life has the Metal Aprons available with Triangular Cut-Outs like the ones originally used on TRON-LE (& many other Stern Premium/LE Games).
If you're new to this Group these have been Unobtainium for quite some time (if you're not new you already knew this and have already GOT one OR STILL want one ;-}).
FYI - they come RAW / Unpainted:
https://www.pinballlife.com/stern-metal-bottom-archapron-with-triangular-cutouts-raw.html
Don't forget to order these additional Parts as you'll need them to mount your new Apron after you get it Plated, Powder Coated or Painted (AND DON'T forget to cover the Six 4-40 Machine Studs on the underside of your New Apron before PC or Paint):
Two Arch Retaining Brackets
https://www.pinballlife.com/stern-arch-retainer-bracket.html
Six mounting screws
https://www.pinballlife.com/6-x-38-unslotted-hex-head-screw.html
Two Apron Mounting Screws (2)
https://www.pinballlife.com/stern-10-32-x-516-metal-apron-mounting-screw.html
Six 4-40 NyLok Nuts
https://www.pinballlife.com/4-40-nylon-insert-lock-nut.html
#11359 3 months ago
Quoted from Pin_-_K:
!! PRODUCT ALERT !!
Six mounting screws
Six 4-40 NyLok Nuts
#11360 3 months ago
MarklarD
You're Welcome !!
I happened to stumble across them looking for some other Apron Parts and I'm always being asked if I still have any left or know where to get them.
You may also need a set of Translucent White Apron Plastics for those Cut-Outs ;-})
https://www.kimballspinballs.com/tron-legacy/
#11361 3 months ago
MarklarD
You're Welcome !!
Thanks for the heads up. I actually ended up ordering this.... https://www.hookedonpinball.com/store/p97/Tron-Pro-Interactive-Apron-Upgrade-Pinball-Mod.html#/
only one left now
Edit: looks like the aprons are sold out too
#11362 3 months ago
I was excited to read this and immediately followed the link...
Page Not Found
Product '' is not available at this time.
Must have sold out fast.
#11363 3 months ago
Quoted from TheBaron:
Page Not Found
Contact them and put your name on a list - if it sold out that fast, they'll make more..
#11364 3 months ago
It sold out in less than 1 hour after being posted here. There definitely seems to be a need for this item. I suggest emailing them.
#11365 3 months ago
they probably made a small run, definitely reach out. they can make more on request if they have enough interest. These are clearly made by them.
#11366 3 months ago
Hey guys. Does anyone here has a set of rails by pinball refinery tgey are willing to sell?
Pic for reference
Screenshot_20230406_085220_Facebook (resized).jpgScreenshot_20230406_085220_Facebook (resized).jpg
#11367 3 months ago
Quoted from Pin_Fandango:
I have contacted Terry a few times over the years regarding the apron. I always get the same response that these are no longer available. I was really surprised there were some posted recently. I have a feeling they just came across some old stock.
#11368 3 months ago
I originally thought the same thing but since they were noted as being "RAW" [not painted/powder coated] I didn't think they could be NOS ?
AFAIK $TERN has NEVER sold any Aprons RAW?
This makes me think PBL/Terry had them remade, if that's the case I'm sure he's seeing the demand and I would think [AND HOPE] PBL will make more.
NOW - IF PBL just happened to find a stash of NOS Raw Aprons, that sadly may be be it - Fingers Crossed and I'm REALLY hoping I'm wrong as I could really use 1 or 2 for my Customers !!
I can't tell you how many requests I STILL get asking if I still have any TRON Style Metal Aprons left.
Until they tuned into Unobtainium a few years ago I always TRIED to keep a 1 or 2 in stock to sell with my TRON-Pro LED Apron Flasher Kits (a great add-on for TRON-Pro's and my Apron LED Kit's was a major an upgrade in brightness for TRON-LE's, ESPECIALLY if you also got my Translucent White Apron Plastics).
I was so busy posting and telling everyone I know I DIDN'T even get one!!
They were already gone when I went back AFTER I posted them here 8-{(
#11369 3 months ago
Taking one for the team is what it's all about.
#11370 3 months ago
I'm in a similar boat. I bought my Tron NIB back when they first came out and I always put off buying a metal apron and figured I'd get around to it. Then it was too late. Every once in awhile I'd take a look at the PBL site and email Terry, but no luck.
I'm also in the same situation with the ramp EL lighting. I kept putting it off because I was nervous about having to put holes in my ramps. By the time I decided to just go for it, they were gone.
#11371 3 months ago
Quoted from punkin:
punkin
- I definitely took 1 for the Team !!
TheBarron
- I was Lucky enough to nab an LE when they were originally released - ours is actually 1 of the 9 (or 10?) NIB TRON-LE's that made their way to the DFW TX. area via FUN! Billiards and Gameroom Superstore in Mesquite TX in 2011.
https://www.ipdb.org/machine.cgi?id=5707
AFAIK there are only two still here (Ken @ Pinball Rebel still has his ;-}) so I don't need either but I have a few Customers that would Love Terry/PBL to make more Aprons !
I'm sure someone will figure out the Fiber Optics for the Ramps as we've got some Genius level Folks on here working on it.
+ IMHO the new Fiber Optic Fibers are a lot brighter than they were in 2011
#11372 3 months ago
Work in progress
#11373 3 months ago
Eggseptional.
#11375 3 months ago
I'm waiting for Ashrams if it becomes a thing a man may be able to obtain.
#11376 3 months ago
ORDERED!!! Thank you for posting that they're back in stock. I can't believe I finally got one.
Now I have to decide what I want to do with it. Keep it black, get it chromed....powder coated blue?
#11377 3 months ago
probably best to match up with whatever your side rails/lockdown bar is
if i ever get a TRON again id chrome it all up.
#11378 3 months ago
Quoted from centerflank:
Probably not going to be possible. I have the limited orange armor from PBL. I could try to match the orange, but I think that would be just too much orange.
I'd consider having it all redone in chrome, but chrome prices are really expensive now. I was quoted $275 for just the apron.
#11379 3 months ago
Finally equipped with ebor's Tron colorisation. It's still a WIP as the plan is to replace this by a larger HD display with 256x64 pixels resolution.
#11380 3 months ago
Quoted from usul27:
Looks amazing. Are you using an esp32 directly wired to LED panels, are is there a shield or PCB available to tie them together?
#11382 3 months ago
Nice. I wonder if we could get something like the Scorbit functionality working (minus the subscription service).
#11383 3 months ago
Quoted from sandro:
Definitely doable. A pattern detector is already there in DMDReader. It would only need a web service and a (relatively simple) pattern configuration.
#11384 3 months ago
Hey all. I effed up my tron le pretty bad. Long story short, I was setting up a new game next to tron and a stripped leg bolt caused it to fall into the left side of Tron and scraped the left body decal.
I’m distraught. If anyone needs amazing karma, and has a stockpiled left cab (or whole set) they would sell me, I would be so grateful.
#11385 3 months ago
Quoted from Ashram56:
Work in progress
Can you tell more about this? Is it planned to have displays in there or ist this just printed images? I wuld love to have one or two video displays in the apron that are synchronized with the game.
#11386 3 months ago
Quoted from paynemic:
Man, I’m sorry that happened
Might be a good time to get in on the mirrored decals that are being worked on
#11387 3 months ago
Quoted from Chosen_S:
Que?
#11389 3 months ago
Oh... Couldn't do it. I have a silk screened cab i think.
#11390 3 months ago
Never heard back and I had indicated I was interested. Maybe it's still in the works or he could not find an affordable printer..
#11391 3 months ago
You want to put decals on a silked screened? It's going to mess up the game's Zen, man! Maybe you can 'try' to fix the damage, ask someone that is good at this or look over Pinside for solutions. Pics?
#11392 3 months ago
Quoted from Saltimbanco:
I didn’t even realize it was silkscreened. Totally different beast, and frankly makes my situation worse I guess. This is as it stands with zero touch up or even wiped clean. The bottom half definitely that’s a slight indentation. Upper part is smooth. Maybe able to magic eraser that?
#11393 3 months ago
I didn’t even realize it was silkscreened. Totally different beast, and frankly makes my situation worse I guess. This is as it stands with zero touch up or even wiped clean. The bottom half definitely that’s a slight indentation. Upper part is smooth. Maybe able to magic eraser that?[quoted image]
Ouch.. yup, the beauty of the LE is having an original silkscreen. But it's almost impossible to fix. Just looking at it makes me sad, I feel for you man. Try removing as much as you can, maybe some fine touching up after with acrylic colors you can mix to exactly match? And when I say touch up, it's almost touching with an extremely pointy/small detailing brush. My first go to place would be to check out HEP... Paging Pin_Fandango, he has the LE, used to have the Pro and worked on both games. He may have some insight!
#11394 3 months ago
Ouch.. yup, the beauty of the LE is having an original silkscreen. But it's almost impossible to fix. Just looking at it makes me sad, I feel for you man. Try removing as much as you can, maybe some fine touching up after with acrylic colors you can much to match? And when I say touch up, it's almost touching with an extremely pointy/small detailing brush. My first go to place would be to check out HEP... Paging Pin_Fandango, he has the LE, used to have the Pro and worked on both games. He may have some insight!
Yeah the art on the LE and some Pros is silk.
Overrated imho for the crap art these games have lol so hopefully one day a better high def radcal comes out.
To fix that I can only think of two companies qualified, one is HEP and the other is TNT amusements. Probably Tnt is your best bet as I don’t think HEP is interested in partial restore jobs as these.
Good luck.
#11395 3 months ago
Good luck.
Yes to try TNT for some restoration work, agreed that HEP probably only wants to do full jobs, thou it wouldn't hurt to ask both for a quote. I wouldn't put radcals on a LE myself, I like to keep things original and collectors will feel the same way if he ever wants to sell his game. Radcals to replace the decals on a Tron Pro, definitely!!
#11396 3 months ago
My after-market cover for the Tron spinning disc has developed a crack. I don't recall where I bought it. Anyone know who makes these? It's light blue acrylic with an orange skirt.
#11397 3 months ago
Probably Pinbits, so it's no longer available as far as I know.
#11398 3 months ago
Hey guys, so i really wanted to get the daft punk decal to put over the right ramp. I had one made and had to order in bulk it actually came out pretty decent. Its a little tricky with the eli kit because need to slide sticker underneath and if doesnt go up all the way it actually folds up in the bottom a tiny bit. but still looks great. Sticker is clear and good quality to it folds nicely. If anyone want some to try for just a few bucks for postage let me know.
I attached a few pictures.
20230629_091409 (resized).jpg20230629_091409 (resized).jpg20230629_093211 (resized).jpg20230629_093211 (resized).jpg20230629_093223 (resized).jpg20230629_093223 (resized).jpg
#11399 89 days ago
Almost there...
#11400 89 days ago
Quoted from usul27:
Almost there...
Ohhhh very cool!
I am in!
$ 26.50
10,750
Medford, NJ
This page was printed from https://pinside.com/pinball/forum/topic/official-tron-lovefest-thread-i-love-it-more-than-lamp/page/228 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
