thats an odd location for a pinball machine lol...
Quoted from rcbrown316:
that's the staging area until movers come to bring it to it's new brothers... can't come soon enough, just ask my wife
Quoted from ATLpb:
my wife always says that to me too
any interest in lit blue flipper buttons? maybe like $25 shipped to continental U.S. ? they were on my game and I switched to chrome.
any interest in pinball pro 8" subwoofer?
Quoted from centerflank:
Finally got my 3rd led flipper bat installed
you need an led ball now in order to see it lol...
Looks like I'm going to order a clear disc, I have the blue one installed, and I just don't see the action that the clear one gets.
I do use the blitz one grand wax, and I've always wondered if my pf is just too slick to see insane ball English.
Can anyone else confirm the difference between the German blue and clear disc?
Also, I don't remember. Do I need to remove the disc rubber from the clear plastic to remove the clear plastic disc from the motor? Pics?
Thank you guys
That looks great! Question is, how do the flippers flip? Are they as strong as the original ones. I had some cheap copies in my machine but that just didn't feel right.
Perhaps he is using the glow in the dark power balls.
Quoted from PeterG:
They feel pretty normal like the last bats that were in.
I put the clear super bands on which are super tight so we will see if they break
Quoted from PeterG:
Did you order those flipper bats in germany you said? Where if I may ask?
And the lighted leg protectors? Also real nice on the Tron!
You should see his lighted lederhosen he got from germany. They'll knock das boots off.
Quoted from PeterG:
The leg protectors are from Mustang Paul
https://pinside.com/pinball/forum/topic/new-led-leg-light-ups
Flipper bats are from Buthamburg
https://pinside.com/pinball/forum/topic/illuminated-flipper-bats#post-3137047
Two rule questions:
1) Is there any time when Gem switch hits do not count (excluding SOS when you've already completed her)
2) After you start Quorra Multiball and add both balls by hitting the recognizer 6 times, the recognizer lowers and spinning disc becomes accessible. Are subsequent hits to the disc counted towards disc MB progress? Are they counted at all? it seems they are not...
Absolutely loving this game and have been inches away from Portal several times. Can't ever get both Quorra and Lightcycle completed in same game!
http://store.steampowered.com/app/392000
Tron Run/r on sale for 5.99 70% off normal 20 buck price.
Ends June 3rd.
Quoted from ATLpb:
Two rule questions:
1. no... just a bad contact cause ball is too fast (happend on mine too)
2. no, giving only small points in that case
is Run/r on the ps3 ps4 network??
Quoted from Frax:
Ends June 3rd.
Quoted from ENDOFLINE:
I have no clue, but unlikely it would be on sale there if so.
Run/r is on PS4. No idea if it's on sale though.
Still can't get over the 3rd flipper. FcKing Fantastic. I PM'd Paul on the leg protectors. GOOD STUFF
I like the DMD reflector "cover" plastic with the Encom logo. Where did you find the Encom logo or how did you label it?
Quoted from DrMark12PA:
I found them on EBay, bought a bunch of them, put 2 on the front legs
Quoted from marcand:
Soooo. What's better? Blue DMD or Color DMD. I have Blue...could go color.
Color DMD. Not even close.
I recently took out the incandescents on my Tron LE GI. Replaced them with frosted cool whites. Pin is much brighter but the El wiring is washed out now. Even in a dark room, the El wiring doesn't seem as vibrant as before.
I have blues and yellows in the inlanes/slings.
I personally don't really like making pins totally blue. What's the best way to brighten up the pin without washing out the EL wiring?
Not a great picture. But before and after
I'm not sure which LED you used. I also went through that error whereby I used high quality 2 SMD frosted bulbs, which washed out the Eli lights. The solution I found was to use the cheapest white LED I could find. The link below worked for me. I picked frosted whites, which turned out to have a slightly blue tint. A dim bluish LED would normally be considered low quality but is a perfect fit for Tron.
http://www.cometpinball.com/mobile/Product.aspx?ProductCode=1RETROLED:
Quoted from nosro:
Yep, these are the ones I've used.
Do you have a picture of video of what your tron looks like nosro?
Thought it would be fitting to put feelers out here for our next small run of chrome aprons for Tron. They will be offered as bare chrome for le owners and full replacement interactive for pro owners. Price will be in line with the acdc and iron man aprons i make. Simply contact me at hookedonpinball@outlook.com for info and check out the vids of aprons at youtube hooked198.
Quoted from HOOKED:
Thought it would be fitting to put feelers out here for our next small run of chrome aprons for Tron. They will be offered as bare chrome for le owners and full replacement interactive for pro owners. Simply contact me at hookedonpinball@outlook.com for info.
emailed
Quoted from FalconPunch:
single smd in the gi. twin smd in the inserts. this is a pro though. as I understand it the eli mods are a bit brighter than stock le ramp lighting
I have a arcade tron mod 2.1 display up for sale i also have the cab parts that would need to be fixed resembled ect. It broke apart from flying ball and tried to fix but it was all hot gluded At least i got 3.1 ver coming If anyone want's the display or cab parts lmk ill let go cheap.
I've always been curious what the difference is in the version of the arcade mods. I have the arcade mod but have no idea what version it is since I bought my Pro with it already installed by previous owner.
What is the difference between versions?
there not too much the newest 3.1 has a brighter screen i think from 2.1 they had light up joystick
Go play some TRON
haha i herd this poster for the new Tron VE
I bet he works out
Quoted from 2Kaulitz:
Shanghai Disneyland opens next week ... And Tron is their new ride.
Looks like it could be cool.
https://www.shanghaidisneyresort.com/en/attractions/tron-lightcycle-power-run/
rd
Quoted from KevInBuffalo:
I think I've asked this before but does anyone know a source for the "-09" plastic on Tron? Mine cracked so I need a new one and don't really wanna buy a whole extra plastic set if I can avoid it. PM me if you have an extra or know where to get one!
I could scan mine with a scanner, if you would like to remake your own.
Swapped in all new flipper assemblies, mechs, coils--all of it. The game wasn't fast enough. Now it's a speed demon for me.
Quoted from Superchicken:
Just finished ramp Eli lights, RGB board and under cabinet lights. I love me some Tron.
DAMN! That TOPPER!
Nice!!!
He fellow bmore guy lol How did you do your topper ?
My buddy made it. It's actually from the video game.
